saggy ass
- ts3doug
- FJRModel: 08 a/07 speed tiple
- x 71
saggy ass
had my '08 loaded down for a camping trip when i noticed the rear end was crazy sloppy. push down on the back and let go and she'd keep boucing like a wore out crown victoria. the adjuster lever on the bottom was loose and appears to be stripped out. thinking it may be time for an aftermarket bit, what seems to be the popular set up for these bikes?
- fencer
- x 215
- x 274
Re: saggy ass
Depends on how much you want to spend.
Some revalve the OE, I went with a Penske. Some go Ohlins.
If you change styles alot (2 vs 1 up) get a remote preload adjuster
- ts3doug
- x 71
Re: saggy ass
i never ride 2 up as wifey hates bikes, really don't load down all that heavy when touring either.
- x 2361
- x 14530
Re: saggy ass
My .02.
Ohlin's YA-036 with the correct spring for your weight in riding gear. Front springs to match as well, fork internals if you can swing it.
The '036 gives you rebound and compression, but no remote preload adjustment - spanner wrenches would be needed to adjust preload. The YA-707 has the remote pre-load adjuster, and the price reflects that.
- FJRModel: 2008
- x 3769
- x 5927
Re: saggy ass
All depends on how much money you can or want to spend and the adjustiblity and ease of adjusting you get for it. Ohlins, Penske, Racetech all make great setups. Then the next issue is now that you have a great shock setup, you're gonna want to work on the forks...
- Intech
- x 1425
- x 3465
Re: saggy ass
I did the GP fork upgrade and Penske 8983 with remote. Worth every penny.
- Name Etc.
Re: saggy ass
I Did a Penske Rear Traxxion AK-20 front with their springs and what not. Love it. Previous to this I did Racetech fork springs and had the rear shock rebuilt, revalved, resprung with Hyperpro Progressive. It is all in a drawer at home if that tells you anything.
ThisMotorCycleLife.net
- ts3doug
- x 71
- Name Etc.
Re: saggy ass
just out of curiosity. The lever, stripped. you mean the hard soft bit? or the twisty rebound adjuster on the bottom? I have all the parts from my old shock. the adjuster and the cable etc. if your cables broke that run the spring adjuster and you just don't wanna spend the money on new aftermarket yet. let me know I can send you the adjuster and the parts. but it kinda sounds like you lost all dampening so.... that is a whole nuther animal.
- ts3doug
- x 71
Re: saggy ass
Just the plastic lever do hickey that is held on with one screw on the bottom of the shock. Honestly I haven't really dug into it yet as I'm a bit suspension dumb. No clue how that dumb lever is supposed to work
- Chuck35
- FJRModel: 2008 FJR1300A
Re: saggy ass
What weight is the revalved shock set up for?Name Etc. wrote:I Did a Penske Rear Traxxion AK-20 front with their springs and what not. Love it. Previous to this I did Racetech fork springs and had the rear shock rebuilt, revalved, resprung with Hyperpro Progressive. It is all in a drawer at home if that tells you anything.
If it is just a spare for you, perhaps you might consider an OEM + cash trade?
I had bought a low mile OEM shock on the other forum awhile back as a spare. I'd like to put off the big upgrade awhile, but the current shock may not allow it.
IBA # 59846
- Name Etc.
Re: saggy ass
It needs Maint.. . . Has about 20,000 since rebuild. Built for me and my wife two up so sprung for bike and 260 ish plus luggage? Can't find the receipt with spring weight? I need something to put on for when I sell and keep penske or need penske rebuilt. Let me look for the paper work.Chuck35 wrote:What weight is the revalved shock set up for?Name Etc. wrote:I Did a Penske Rear Traxxion AK-20 front with their springs and what not. Love it. Previous to this I did Racetech fork springs and had the rear shock rebuilt, revalved, resprung with Hyperpro Progressive. It is all in a drawer at home if that tells you anything.
- Name Etc.
Re: saggy ass
I say all that because I didn't have any luck finding a person to rebuild this shock a second time. I know they are there but the guy who built mine can't be found anymore. So You would need to have the basic fluid change/bushings or whatever done. Good shock, worked well. was ready for work again.Name Etc. wrote:It needs Maint.. . . Has about 20,000 since rebuild. Built for me and my wife two up so sprung for bike and 260 ish plus luggage? Can't find the receipt with spring weight? I need something to put on for when I sell and keep penske or need penske rebuilt. Let me look for the paper work.Chuck35 wrote:What weight is the revalved shock set up for?Name Etc. wrote:I Did a Penske Rear Traxxion AK-20 front with their springs and what not. Love it. Previous to this I did Racetech fork springs and had the rear shock rebuilt, revalved, resprung with Hyperpro Progressive. It is all in a drawer at home if that tells you anything.
- Chuck35
Re: saggy ass
It must have been Sasquatch. Word over on ADV is he got a lengthy prison sentence for kiddy porn or some such. I also heard he did fantastic work. I think I'd need about an 850 lb spring and that would be a bit on the firm side. Had you felt it was worn out already or did you just replace it due to mileage?
IBA # 59846
- Name Etc.
Re: saggy ass
Miles actually but, I found a different reason for my weaving bike. It may be just fine and i think the 850 sounds about right but it is a progressive wound spring. and you are correct on the rebuilder. And the reason I believe too, but I am not sure....Chuck35 wrote:It must have been Sasquatch. Word over on ADV is he got a lengthy prison sentence for kiddy porn or some such. I also heard he did fantastic work. I think I'd need about an 850 lb spring and that would be a bit on the firm side. Had you felt it was worn out already or did you just replace it due to mileage?
- ts3doug
- x 71
- x 47388
- x 20119
Re: saggy ass
Might that contribute to the saggy ass?ts3doug wrote:Well shit, my shock money may be going to a new refrigerator
- FJRModel: 2013 FJR1300 and 1999 ZRX1100
Re: saggy ass
A buddy, with a GenII, that I can't come close to staying with on a crooked road swears by Hagon. Anyone here use them?
- Name Etc.
Re: saggy ass
there was one guy on here that posted about his. but I cant find it. Might have been the previous "on here."Old Guy wrote:A buddy, with a GenII, that I can't come close to staying with on a crooked road swears by Hagon. Anyone here use them?
- Name Etc.
Re: saggy ass
how bout this one. new to the US?
http://www.nitron.co.uk/CatalogueRetrie ... ectType=27" onclick="window.open(this.href);return false;
