CRS strikes again - Relay Arm Removal?
Forum rules
x 120
x 1553
Working on KrZy8 relay arm.
I recall that to clear the upper relay arm bolt the CS bolts had to be cut then reversed with new ones..
??? Can this be done with CS deployed or does it have to be in the UP position?
Pic from when I did Naomi. Are the CS bolts in the pic OEM or already reversed?
Sigh.
x 11359
x 8168
Re: CRS strikes again - Relay Arm Removal?
Those appear to be in the original position. It looks like the nuts are on the outside which would require the bolts to move to the middle and they will not clear the mechanical parts.
Just my opinion.
x 13774
x 12738
The CS needs to be retracted.
x 1011
x 1502
Don't quote me on this but this bolts - with the nuts to the outside is the orientation you want to get them out easy. If orientated the other way the exhaust interferes with removing the bolt.
LOTS of info in this thread: https://www.fjrforum.com/threads/rear-s ... st-1030352
See this post. Your bolts are in the good orientation. https://www.fjrforum.com/threads/rear-s ... st-1038746
FJRoss loved this
'04 FJR (X2) -- '09 FJR (X2) -- '13 FJR (X3) -- '14 FJR ES -- '17 FJR ES -- '23 FJR ES -- '14 BMW GSA What can I say? I have issues!
x 120
x 1553
Thanks Everyone!
Will do it proper next tire change. More parts ordered. Hey, it's only money, yes?
