CODE 19
- FJRModel: 05 AT
- x 3
CODE 19
I’ve got a 2015 with 21k on it, I got a code 19 yesterday but it still started. Today I got a code 19 but it didn’t start. Other threads have said it’s either the ignition switch or the kickstand switch, but my question is, can those really go out at 21k & which one is more likely to go out? The bike doesn’t have grime built up on the kickstand area but who knows. TIA.
- x 3517
- x 12938
Re: CODE 19
If you go into DiAG, in the sensor operation table there is d:020 which shows the sidestand switch. While in gear, it will indicate ON when sidestand switch is up, and OFF when down. The blue wire goes direct to the fuel pump relay, the black to ground. Note Gen3's do have ground spiders....
Above the rad, taped to the wire harness, is where the ground spiders reside, I think 3. Probably worth a look to see if not oxidized and clean them anyway....
I am assuming when it won't start, the fuel pump did not cycle. If it did, then it's not the sidestand switch.... have you checked the Fuel Injection fuse is OK/clean?
Side stand switch connector might be hiding under the left end of the throttle bodies? Follow the wire up to find it.... maybe by the air cleaner? I would not expect it to fail that early.
extrememarine and CollingsBob loved this
- FJRModel: 05 AT
- x 3
Re: CODE 19
Ok thanks RaYzerman. I’ll get into the Diag & check that out. I don’t remember if the fuel pump cycled, but the last 2 times trying to start it it did & no code popped up either. Thanks for the info I’ll check those things out you said, do you think it could be the ignition issue possibly?raYzerman wrote:If you go into DiAG, in the sensor operation table there is d:020 which shows the sidestand switch. While in gear, it will indicate ON when sidestand switch is up, and OFF when down. The blue wire goes direct to the fuel pump relay, the black to ground. Note Gen3's do have ground spiders....
- x 3517
- x 12938
Re: CODE 19
We haven't heard much if anything on Gen3 ignition switches..... if the fuel pump runs, then the sidestand switch is OK (at that moment), as well as the other conditions that will let fuel pump run/FI system works. Might want to experiment and see if it makes any difference with it in gear, sidestand up and clutch switch engaged, or up while in neutral or down while in neutral. But intermittent is a bear to diagnose sometimes.
BTW, I am assuming you've found the starter will crank over, but no start....??
There are some multi-way connectors up forward of the valve cover, might wanna check those aren't corroded as some aren't waterproof and that's a vulnerable area with open space above the rad. However, side stand switch again is wired direct to the fuel pump relay.
Check the 4-way that's plugged into the starter relay outboard of the battery.... that can get corroded and will cause FI issues, direct connection to the fuel pump relay as well.
For ignition switch, if it were failing, several other things wouldn't light up.... Ignition fuse, Backup fuse, Signals, tail lamp, licence lamp.... if in neutral does the neutral light always light up when out of gear?
- FJRModel: 05 AT
- x 3
Re: CODE 19
Thanks Rayzerman, been busy so I will run down all that you’ve said this weekend. Yes it’ll crank over just won’t start. Last 3 days it’s started each time I’ve tried but still hasn’t flashed a code. Thanks for your help.raYzerman wrote:We haven't heard much if anything on Gen3 ignition switches..... if the fuel pump runs, then the sidestand switch is OK (at that moment), as well as the other conditions that will let fuel pump run/FI system works. Might want to experiment and see if it makes any difference with it in gear, sidestand up and clutch switch engaged, or up while in neutral or down while in neutral. But intermittent is a bear to diagnose sometimes.
- Road Runner
- x 2425
- x 1143
Re: CODE 19
I had a code 19 on a Gen 2 (don't know if Gen 3 is same) which turned out to be the key switch. It was also intermittent. If I remember correctly, the FP did run when key was cycled and still no run. There's a wire that runs from key switch to ECM . When the ECM see's 12 volts on that wire it completes the ground circuit or positive circuit for the coils and allows the coils to spark, (it basically turns the coils on or off). Everything else worked as designed.
If it has that same wiring, I think it was a blue wire running from ignition switch to ECM. Use a digital multi meter to check it for 12 volts when key is turned on, but make sure this is all correct for Gen 3 before you do it. Always use digital multi meter so you don't back feed anything.
I ended up taking the ignition switch apart and found dirty contacts which I cleaned and greased and never had that issue again.
Like I said I don't know if it is the same but may be worth a looky and wiring diagram if you have one.
- Road Runner
- x 2425
- x 1143
Re: CODE 19
On a Gen 2 the wire that runs between the ignition switch harness and the ECM is blue with a green tracer. FYI.
- FJRModel: 05 AT
- x 3
Re: CODE 19
Sounds good I’ll add it to the solutions list.Road Runner wrote:I had a code 19 on a Gen 2 (don't know if Gen 3 is same) which turned out to be the key switch. It was also intermittent. If I remember correctly, the FP did run when key was cycled and still no run. There's a wire that runs from key switch to ECM . When the ECM see's 12 volts on that wire it completes the ground circuit or positive circuit for the coils and allows the coils to spark, (it basically turns the coils on or off). Everything else worked as designed.
- FJRModel: 05 AT
- x 3
Re: CODE 19
Well I tore into it today & have yet to be able to replicate the code(maybe that’s a good thing) I checked all the connections I could find I didn’t find any that looked like they were corroded or anything wrong with them. I’ve tried starting it with it in gear, in neutral, clutch in, clutch out, kickstand up, kickstand down, any combination of all of those & after 30 + starts have yet to have an issue or replicate the code. Unless it’s possibly the ignition switch or I missed something else I’m at a loss. The kickstand worked both ways Rayzerman told me to try it, diagnostic code 20 showed it was correctly working, & every time I turned it on the FI worked. Thanks for the help & ideas I’m still open to any other ideas but my last question is, could it just have been something to cause a one time code error but nothing permanent?
TIA
TIA
- x 3517
- x 12938
Re: CODE 19
The code 19 is for the sidestand switch, which was intermittent given your start vs. no start..... it's likely the contacts are all cleaned up now that you've excercised it, checked other connections, etc.... I'd think it was a one-time thing being you can't get it to repeat... ride on. It should start in neutral regardless of the sidestand switch. If you have the problem again, activate it a few times and ensure the sidestand is indeed able to be fully up (not held slightly down due to dirt, etc.). If you're worried about it, locate the connector for it, and have something to bridge it in an emergency, then it will think it's retracted, i.e., ON.
- FJRModel: 05 AT
- x 3
Re: CODE 19
Thanks Rayzerman I think you’re right to just ride on & that’s my plan until it havens again. ( hopefully not!)raYzerman wrote:The code 19 is for the sidestand switch, which was intermittent given your start vs. no start..... it's likely the contacts are all cleaned up now that you've excercised it, checked other connections, etc.... I'd think it was a one-time thing being you can't get it to repeat... ride on. It should start in neutral regardless of the sidestand switch. If you have the problem again, activate it a few times and ensure the sidestand is indeed able to be fully up (not held slightly down due to dirt, etc.). If you're worried about it, locate the connector for it, and have something to bridge it in an emergency, then it will think it's retracted, i.e., ON.
Thanks again.
