Soldering 101
Forum rules
Soldering 101
raYzerman wrote: as I pressed on the LED, it works! Surface mounted LED rectangular (SMD)... will require delicate re-solder by somebody with experience and good eyes, or replace the module.
Riders,
Lots of people say that soldering is tricky, but if they dumped their poor old tools on me, I'd have a hard time myself. In my job as an aircraft electronics tech, everybody on my team would say they could give an appendectomy to a termite. 8-) None of us had super-powers, but we did have the right tooling.
The average would be somebody thinking that rosin was actually good flux, or that acid flux was okay for use on electronics. Flux means FLOW, and you want your solder to flow like water on your connections. Acid flux is for plumbing, if even that. Acid flux will destroy electronics, unless you clean it up with baking soda and water after the work. Rosin flux is lame; it does not work on many metals, and it needs alcohol or a good solvent (safe for electronics) to wash away the flux after the job is done. Forget that old stuff; this is not the 1950s anymore. The best commonly available flux that I know is LA-CO flux, costing about US$ 3.50 for 2 oz. (113 g). This little jar will last you a long time. LA-CO flux washes away with plain water, and it is safe for drinking water pipes.
https://markal.com/collections/solderin ... 4786921519
These same folks might have a soldering iron that is suitable for building power plants, maybe with a "tip" half an inch (14 mm) across. Bogus. You need a temperature-controllable soldering iron in the range of 75 Watts, and a damp sponge to wipe the tip clean and shiny each time before you touch the soldering iron to the work. A small chisel tip (1/8" or 3 mm wide) is a good choice, at the business end. Crank up the tip temperature just enough for good progress on the work, but not so high that the tip gets "dirty" (oxidized) too fast. Just one example here:
https://www.amazon.com/Soldering-Statio ... 0CDNWLJWJ/
Now okay, there are a few things to know. Leaving flux on the board after soldering is a recipe for a quick failure, even if the gear will operate at the time when you are done. Cut down the bristles of an acid brush to get short firm brush bristles, and use it with the correct solvent (usually alcohol) and toilet paper to clean away all flux when you are finished. Old flux will collect dirt and contaminnts, and may damage the printed circuitry.
63-37 solder (lead/tin, by percentages) melts faster than the others. 60-40 solder is the most common old-style solder, but it is getting rare. I recommend lead-free solder, unless you have a vented work table to draw off the lead-laced fumes.
It's a good idea to remove all of the old solder from a job, before installing new parts. For that, you need Soder-Wick, or some similar copper braid with flux. Lay the braid on the old solder, apply the soldering iron, and the hot copper braid will absorb the old solder like magic. Add flux if needed, for good results. Copper braid goes for maybe US$ 1.00 per foot (30 cm), but you can pay much more. There is no great benefit from any extra expense, for copper braid.
Eyeglasses? Yeah, I have them, but perfect vision is not needed. What IS needed for fine electronics work is a low-power microscope, preferably the binocular type. The one-eyed microscope that you had as a kid is just too powerful. You need maybe 15 X power, +/- five X or ten X, and NOT what a microbiologist would use. You can find them in the thrift stores, or on websites like eBay and Craigslist. You will be amazed at how well you can do micro-soldering with this good tool.
Practice definitely helps. Make up some repair jobs on old junk electronic parts, and sharpen your skills. You can be a soldering ace in a matter of days. When the job is done, your soldering should look like new silver. Dirty, gray, granular soldering is sub-standard. A clean iron, good flux, and new solder are the ingredients for reliable repair.
Mudslide Miller, JoelTheMole, PhilJet09 and 13 others loved this
x 6275
x 10340
Re: Soldering 101
Good stuff! I thought those magnification glasses were dorky till I bought some. Game changer, especially with the built in light.
I'd only ever soldered one or two wires here and there. Getting into the expensive hobby of building custom keyboards sure does give you some practice with your equipment. I'm still hobby level but better than I used to be.
Hppants, 0face, Cav47 and 2 others loved this
x 734
x 6952
Re: Soldering 101
Red, you’ve increased my knowledge about soldering immensely. There wasn’t much there to start with, but there is a bit now.
bigjohnsd, Hppants, wheatonFJR and 2 others loved this
Re: Soldering 101
gixxerjasen wrote: Wed Jan 17, 2024 3:47 pm Good stuff! I thought those magnification glasses were dorky till I bought some. Game changer, especially with the built in light.
https://photos.smugmug.com/Keyboards/Si ... 084-XL.jpg
https://photos.smugmug.com/Keyboards/Si ... 693-XL.jpg
https://photos.smugmug.com/Keyboards/Si ... 719-XL.jpg
https://photos.smugmug.com/Keyboards/Ot ... 309-X2.jpg
GixxerJasen,
Definitely, go with what works for you.
I have the eyeshade magnifiers. The ones with lights are good, and better if you can aim the lights somehow.
There are some eyeshade magnifiers with multiple lenses. You can swap out lenses, or even combine two sets for more magnification.
Some of them will let you use eyeglasses normally under them, even better, if you wear glasses.
x 6275
x 10340
Re: Soldering 101
I can aim the light up or down which is helpful because the default position is not good. I can also swap lenses, but can't combine them. I usually just go straight for the max magnification. Works well for soldering, painting, digging splinters out of fingers, etc. They were cheap ones off Amazon, there's better, but for the amount of time I use them, they work well. In fact they get used way more than I thought they would. I probably pull them out once every month or so for this or that. I haven't tried them over my glasses, I think there's room but I can usually make it work without them.
x 3884
x 6044
Re: Soldering 101
gixxerjasen wrote: Wed Jan 17, 2024 3:47 pm Getting into the expensive hobby of building custom keyboards...
My office is in the Mechanical Keyboard Building (MK Tech Center) I just bought a custom keyboard from them. You should see some of their stuff... There's a bunch of gamers there too...I know when they're all having a freaking tournament because the network slows down in the building trying to render all that shit.
:threadjack:
Back to your regular programming.
Hppants, gixxerjasen, and wheatonFJR loved this
x 3517
x 12938
Re: Soldering 101
I get it all and have done some soldering in my day...... so I went to my local electronics supply, a fairly large place, asked if they had any SMD's... not sure, look over there (back in the corner). Lots of regular wired LED's, not an SMD to be found... a million resistor choices too... no good to me. Next I perused their solder, flux, irons..... I'd spend a ton for this one wee job and likely not use it much again..... nope, I'm going to look for a professional....
Re: Soldering 101
raYzerman wrote: Sat Jan 20, 2024 2:42 pmI get it all and have done some soldering in my day...... so I went to my local electronics supply, a fairly large place, asked if they had any SMD's... not sure, look over there (back in the corner). Lots of regular wired LED's, not an SMD to be found... a million resistor choices too... no good to me. Next I perused their solder, flux, irons..... I'd spend a ton for this one wee job and likely not use it much again..... nope, I'm going to look for a professional....
raYzerman,
Yes, tooling at retail can be expensive. The items that I linked are not.
These guys (below) have had good phone tech support for me in the past:
www.digikey.com/product-search/en
https://www.jameco.com/webapp/wcs/store ... d=-1&rfr=1
At a minimum, they can probably get you to the right sources, for almost anything electronic.
The manufacturer (by Part Number) should also have phone tech support available.
If you call and tell the manufacturer that you are an independent inventor,
they may even "sample" a small number of the parts straight to you, no charge.
x 3517
x 12938
Re: Soldering 101
Red I appreciate all your knowledge and advice, but I'd only go there if I was taking it up as a hobby or something like that. For the one-off, just pay the professionals.....
Got another email from Scott at BlueGauges... he looked at the pics and said he could fix me up in like 10 minutes, and went on to say he wouldn't even charge me anything.... I replied I was having none of that nonsense, I won't let him work for nothing..... so we're likely hooking up next week and git 'er done. I'm all excited.
El Toro Joe, bigjohnsd, and gixxerjasen loved this
Powerman
FJRModel: 06fjr
x 326
x 1744
Re: Soldering 101
Post by Powerman »
Taught "Aerospace" soldering in the AirForce, better than mowing lawns in Tech school.
Pretty low tech actually.
SMD stuff is hard with old guy eyes, microscope sounds like a good idea.
Re: Soldering 101
Powerman wrote: Sat Jan 20, 2024 10:22 pmTaught "Aerospace" soldering in the AirForce, better than mowing lawns in Tech school. Pretty low tech actually.
Powerman,
You can sometimes pick up a good binocular microscope on the "For Sale" websites or Fleabay. I have seen them in the thrift stores, too. One of the local TV stations here has a Classifieds website; I got a screaming deal on mine there. Sometimes you just need to put the word out to friends and relations.
15X to 30X will do the job for you. Some microscopes will have a range of magnifications built in, or a even a set of various low-power optics as part of the deal. You may not need to have eyes pressed to the optics, with a binocular microscope. You can usually position your eyes above the optics by half an inch (1 cm) or so, and see an easy view of the work with both eyes. Try before you buy. Happy hunting. 8-)
gixxerjasen and N4HHE loved this
JoelTheMole
x 46
x 38
Re: Soldering 101
Post by JoelTheMole »
Red wrote: Wed Jan 17, 2024 3:24 pm
Thanks for this, I ordered up that soldering station and flux you recommended to try out.
x 952
Re: Soldering 101
N4HHE and JoelTheMole loved this
x 48381
x 20486
Re: Soldering 101
FJRoss wrote: Mon Apr 28, 2025 11:13 am Image
Lol!!!!
x 3517
x 12938
Re: Soldering 101
N4HHE, wheatonFJR, and CollingsBob loved this
Re: Soldering 101
Riders,
In case you want to see the whole process in one lump, I made up this web page, Soldering 101. You can bookmark the page, or print it out.
https://user.xmission.com/~red/Solderin ... ing101.htm
wheatonFJR, FJRoss, and JoelTheMole loved this
Mudslide Miller
FJRModel: 2014 FJR1300ES
x 182
x 176
Re: Soldering 101
Post by Mudslide Miller »
Red,
Fantastic write up on soldering. I worked at Honeywell for 25 years & was solder certified in the electrical dept working on commercial aircraft APU's.
Soldered tons of various switches, old school wiring harnesses that had solder connectors (everything is crimped today, for the most part) & a few different small circuit boards but nothing to the extent that the electronics divisions dealt with. It is great to have that knowledge. Even being 10 years into retirement, I would not hesitate to pick up a soldering iron again.
Your post was very thorough & accurate, so I have nothing really to add other than we also made good use of a solder sucker to remove solder from connector pins where the solder wick works best on exposed solder surfaces.
Well done!!
Re: Soldering 101
[deleted]
Re: Soldering 101
[deleted]
Re: Soldering 101
Mudslide Miller wrote: Tue Apr 29, 2025 2:39 am Red,
Well done!!
Mudslide Miller,
Thanks. Knowing and using the right tools can make a world of difference.
Most people who have problems when soldering are really having problems with poor tooling.
I know of three types of solder suckers, beyond SolderWick.
All of these gadgets are like a hollow soldering iron, with a vacuum source.
The type with an electrical vacuum pump motor is nice, but kinda pricey, for home use.
A similar type uses compressed air instead of a vacuum pump. The compressed air creates suction using a venturi, so it's more complex and costly than the first type. Compressors ain't cheap, and both of these gadgets put a lot of metal dust (solder dust and fumes) into your air.
One type (SoldaPult) uses a big spring-loaded syringe to make the suction. They jump when used, and they are a PITA.
I did not mention these gadgets because most connectors are crimped today, as you said, and not soldered. You may spot such de-soldering gadgets at a thrift shop or yard sale, but none are worth the retail price, for home use. The ones that make solder dust really need venting to the outside air, so that means creating a dedicated soldering station/ vented workbench. Not very practical to make the job safe, in your home. These gadgets are for production shop use, not a hobbyist at home.
SolderWick and some good ventilation will do the job for most home uses.
