The 2013 I bought has a LED unit instead of the reflector on the bottom edge of the rear fender. I assume this is an aftermarket unit. Unfortunately the lens has been lost and I'm trying to find a source for the LED unit. Has anyone else replaced the reflector with a LED unit, and if so, where did you get it????
Thanks -Glen
Rear Reflector/LED
- FJRModel: Sadly no FJR
- x 195
- x 165
- x 2756
- x 195
- x 165
Re: Rear Reflector/LED
Thanks. Good idea but that's not the one.FJRoss wrote: ↑Fri Aug 04, 2023 5:56 pm Maybe there???
https://www.whelen.com/product/tir3-lin3-series/
- x 12959
Electrical Connection used to sell the rectanguar LED reflector replacements... You may find them at Wingstuff or order direct from AliExpress.... They aren't particularly bright, and you may find a rectangular trailer or truck clearance light is just as bright.
This may also work if the size is right....
https://electricalconnection.com/index. ... light-kit/
- x 195
- x 165
Thanks. wingstuff has a unit that looks almost the same as what I have. Guess I would need to purchase the complete unit, not just the lens. I may just replace it with the OEM reflector if I don't find the same unit somewhere.raYzerman wrote: ↑Fri Aug 04, 2023 9:17 pm Electrical Connection used to sell the rectanguar LED reflector replacements... You may find them at Wingstuff or order direct from AliExpress.... They aren't particularly bright, and you may find a rectangular trailer or truck clearance light is just as bright.
- x 2756
Not the same, but Hyperlites makes some great brake/marker/signal solutions for motorcyclkes.
https://hyperlites.com/brake-lights/
- x 195
- x 165
Found something on ebay that looks almost the same - red rectangular with 24 leds
Description: 2X 24 LED Reflector Stop Tail Light Brake Turn Signal Lamp For Motorcycle Car
aliexpress also has something similar in a variety of colors.
Their description: 2x/4x/6x 12V Red Yellow White Rectangle Universal Truck LED Motorcycle Led Turn Signal Reflector Tail Light Brake Stop Lights
FJRoss loved this
- x 12959
Yes, shoulda explained, no lenses only available, the 24 LED ones are basically all you can get in standard reflector size... all the same, all made in China.
Meanwhile I do have Hyperlites and you will not fail to be noticed...... even the smaller 8 LED ones. I get comments on mine.
Now those Whelen TIR3 (and lots of knock-offs) are obnoxious brake lights (police strobes), please don't ride in front of me unless you can switch it off.
senecahome loved this
