Bike will not start
wellsj
x 10
Bike will not start
Post by wellsj »
Had a PCIII for a while and decided to go ahead and finally put the thing on the bike while I was adding a switched power block for accessories. I plugged in unit, connected ground wire and unplugged the O2 sensor.
Put bike all back together and go to start and all it does is turn over.
When I turn the key on I do see the light graph light up on the PCIII, so I know it is getting power.
Can unplugging the O2 sensor cause this?
For those that may ask, this is a 2007 model
Calimus
GEEK
FJRModel: 05'
x 17
Re: Bike will not start
Post by Calimus »
It shouldn't since you are supposed to leave the O2 unplugged with a PCIII. While I was lucky and mine cam pre-installed on my bike, there's a chance that you might have crossed a wire or not made a good connection somewhere. Best bet is to go back through it and take your time. I've seen posts about no-starts on PCIII installs before and it's usually what I mentioned. Could also be the unit itself, it's electronic and that means it can shit the bed at any time sadly.
My process of elimination would be as follows
1. Double check all wiring
2. Remove the switched power block and use normal power
3. Bypass switched power and PCIII (back to stock) and make sure something else isn't going on.
Trying to be different, just like everyone else.
Name Etc.
Post by Name Etc. »
Are you sure you unplugged o2 sensor. When I installed mine I unplugged the crank position sensor because I just eyeballed the wire trace. It would not start and I quickly realized wrong connector. They are in same kinda location... Sorta. Dumb mistake took seconds to realize what I did.
ThisMotorCycleLife.net
wellsj
x 10
Post by wellsj »
Went by a picture that I found posted somewhere showing the O2 sensor wire. Black connector, 4 wires ( 2 black, 1 blue, 1 white)
Name Etc.
Post by Name Etc. »
Is your tank still up?
I think my 07 connector is white? Can't remember.
x 13145
x 6352
Jim... Either you pulled the wrong sensor or your ground is not good. Both will give you the same result. You can use it with the sensor plugged in. Put it back and see what happens.
If those check out ok, the unit may be bad. They're pretty plug and play.
yamafitter
x 76
x 703
Post by yamafitter »
It may be something even simplier. Did you plug the connectors back onto the tank when you put the bike back together? Please don't ask how I know this can cause a problem. :oops:
Sometimes simple things like this get overlooked towards the end of the job. If you turn the key to on and don't hear the fuel pump run until there is pressure then start with the connectors under the tank.
x 2360
x 14517
Jim,
I had a PCiii die on my '04. It cycled and showed the gtg lights, but we putting no fuel to the cylinders. Once unplugged, the bike fired right up.
I'd start with backing up to a stock set up - unplug the pciii and ensure everything is plugged back in, and try to start the bike. If it starts, bingo.
Do you have a map loaded to the pciii? It's most likely something simple...
wellsj
x 10
Post by wellsj »
Sure that the plugs are connected under tank as the fuel gauge works and I hear the pump.
Wayne I think it has the Useless Pickles map loaded as the unit came from another forum member.
wellsj
x 10
Post by wellsj »
Ok, AJ wins the prize..... Bad ground was the problem.
Thanks for the ideas folks.
Jim
x 2360
x 14517
Easy day then, glad it was a simple fix...
wellsj wrote:Ok, AJ wins the prize..... Bad ground was the problem.
Jim
beemerdons
FJRModel: 2013 FJR
x 11
Post by beemerdons »
extrememarine wrote:Easy day then, glad it was a simple fix...
Jim
Once again living proof AJ 'Zilla is the smartest person on the FJRiders Forum! May the Good Lord help us all, each and every one! jes' sayin' and nuff said!
Certifiable Old Fart
x 13145
x 6352
Gawd...I'm a fuckin' genius...Trapped in this body!
x 47320
x 20092
Jim
Zilla wins again!
That guy is just too smart!
x 3433
x 12701
HotRodZilla wrote:Gawd...I'm a fuckin' genius...Trapped in this body!
Hey, FG, can you send me the winning numbers for tomorrow night's lottery draw? Countin' on ya!
