Aftermarket brake and clutch levers
x 4466
x 12619
Thinking about these. I have zero knowledge about what is out there. Anything to stay away from? I know a ton of them are from China. Anything specific I'd want to look for?
x 14699
Re: Aftermarket brake and clutch levers
I have a set of Pazzo clones from fleabay. I like the shape (more rounded) and adjustability to bring the front brake lever a tad closer to the grip. The only issue I've had is the finish fades over time. I'll get a pictures later and add here.
HotRodZilla and Festus loved this
x 12959
They're all from China..... I have used several sets on the various bikes I've had, no issues whatsoever. They all seem to be made in the same place, adapter parts are stamped with the code specific to the bike (same stamps on the genuine Pazzo's I had, but Pazzo handles are unique). The anodizing depending on colour will fade with time, as anodizing does, or wears off somewhat with glove usage. I've had no issues with them, I like the functionality and the range of adjustment.
x 11002
x 4246
If you want the best...get these, I love mine. They ain't inexpensive
https://psr-usa.com/checkout/cart/
CollingsBob
FJRModel: 2024 BMW R1300 GS
x 6412
x 2794
Post by CollingsBob »
I have Pazzo levers on my 17..I like the feel of the levers in my hands and the slightly reduced reach - I think they offer a better mechanical advantage over the stock levers. Women have also told me that since I put them on my bike that they find me more attractive.
HotRodZilla, FJRPittsburgh, ice station zebra and 1 others loved this
Pazzos for me. The black anodizing is still great and zero mechanical issues with one set of Pazzos in 285,000 miles and fifteen years on two different FJRs.
Abercrombie FJR and HotRodZilla loved this
RacinRay
x 172
x 875
Post by RacinRay »
I have Pazzos on both of my bikes. The quality and feel is top notch.
x 48429
x 20499
CollingsBob wrote: Fri Jul 22, 2022 10:19 am ...Women have also told me that since I put them on my bike that they find me attractive.
Really??
CollingsBob
x 6412
x 2794
wheatonFJR wrote: Fri Jul 22, 2022 10:45 am
Really??
Lmao
x 2627
x 2118
I have Pazzos and a mixture of knock-offs. As mentioned, the knock-offs finish will fade but in general I find they function as well as the name brand high $$ levers. YMMV
x 4466
x 12619
Any thoughts/logic on the shorter ones vs the standard size? Any major benefit or just a preference on the short ones?
x 12959
I get the long ones, or the adjustable ones. They are already short enough, don't know why you'd want to go shorter.
Festus loved this
x 11002
x 4246
Festus wrote: Fri Jul 22, 2022 11:29 am Any thoughts/logic on the shorter ones vs the standard size? Any major benefit or just a preference on the short ones?
Check my link...the PSR levers are adjustable short or long.
(never mind I see the cart is empty now)
check this link...https://psr-usa.com/gp-lever.html#.YtrT8nbMKUk
x 4466
x 12619
El Toro Joe wrote: Fri Jul 22, 2022 12:42 pm
I did. It comes up as an empty cart and if you select "Sport Touring" it only shows 1 option and that's for a Gold Wing so I wasn't sure which ones you were pointing to.
x 12959
Festus, I will check my stash.... if I still have a spare set (you may not like the colour), I'll bring them to EOM for you and you're welcome to keep them.
HotRodZilla and El Toro Joe loved this
x 12310
x 11257
My only issue with the short Chinese levers on both my FJR and the first GSA was that over 55,000 miles on either bike the pivot holes wore a little oblong.
Both Yamaha and BMW OEM levers have hard bushings to pivot on, the Chinese levers just have a hole in the aluminum lever.
No issues on the FJR, eventually I had to replace the left lever on the BMW because the cruise would not stay engaged. I put the OEM lever back on and it worked fine.
x 13186
x 6371
I also have Pazzos. The ONLY reason I bought them was because a Forum member began an on-line store, YEARS ago and I was supporting him. Also didn't hurt that we got a discount. I figured they were just bling.
I was wrong. I LOVE my Pazzo levers. The feel is completely different and the adjustability is really convenient. Pazzos will be one of the first things I add to any nee bike.
The only guy I knew that had short levers was FUBAR. He may have had just a short brake lever, but I don't remember. He did say that with the loss of leverage, he wished he had gone with the full length lever(s).
Abercrombie FJR
x 521
x 1827
Post by Abercrombie FJR »
Festus wrote: Fri Jul 22, 2022 12:45 pm I did. It comes up as an empty cart and if you select "Sport Touring" it only shows 1 option and that's for a Gold Wing so I wasn't sure which ones you were pointing to.
FJRs are listed under sport bikes.
x 4466
x 12619
raYzerman wrote: Fri Jul 22, 2022 12:58 pm Festus, I will check my stash.... if I still have a spare set (you may not like the colour), I'll bring them to EOM for you and you're welcome to keep them.
Thanks for the offer Ray, no need, I'll grab a pair at some point. It's not likely that I'll be at EOM.
CollingsBob
x 6412
x 2794
Pazzo levers are available from
https://motorcycleinnovations.ca/collec ... zzo-racing
Members of FJR Canada get a discount
