New Member
Stop in & tell us who you are, where you are from, etc.
Dale_I
FJRModel: 2008 FJR1300 AE
x 8
x 49
New Member
Post by Dale_I »
I don't follow this forum a lot, but registered during attendance at CFR2022. I'm coming from an ST1100 and was (and am) pretty active in the ST forums. Been riding for 40 years and just love it.
Hoping to meet more of you in Nakusp, BC, in a couple weeks... Dale
Bounce and CollingsBob loved this
2008 FJR1300 AE
IBR #79256 / STOC #5341
x 2624
x 2114
Re: New Member
Welcome from metro Seattle! See you in Nakusp.
Dale_I loved this
x 6387
Re: New Member
Welcome, Dale. Make yourself at home!
Rob
Flatistan
Dale_I loved this
x 10993
x 4231
Re: New Member
Welcome, from the north coast of Ohio
Dale_I loved this
x 14699
Re: New Member
Hello and welcome - looking forward to hearing about CFR '22 - we won't be able to make it that far west this year...
Dale_I loved this
Old Grizz
x 26
Re: New Member
Post by Old Grizz »
Good Day All, Old Fart Here
As a bit of an intro.
I am 70 years old, been riding since 1970 back in the dark ages..
My current ride is a 2012 FJR.
It has a few things added.
Windshield extension
Two Bros Exhaust
Power Commander
Electronic Cruise Control
SW Motec Rack
Denali Phone Charger
Grip Puppies
Handlebar riser
I love the bike, my only complaint is that she is a proper bitch to get on the centre stand
Ride Safe All
Sent from my SM-G781W using Tapatalk
Hppants, FastPappy, CollingsBob and 2 others loved this
x 48396
x 20486
Re: New Member
Welcome!
They fixed that center stand on the 13s.
x 3519
x 12943
Re: New Member
Dale_I wrote: Tue Jun 14, 2022 4:16 pm I don't follow this forum a lot, but registered during attendance at CFR2022. I'm coming from an ST1100 and was (and am) pretty active in the ST forums. Been riding for 40 years and just love it.
Another one of the old ST gang..... welcome. See ya in Nakusp.....
Re: New Member
Old Grizz wrote: Wed Jun 15, 2022 5:16 pmGood Day All, Old Fart Here
Ride Safe All
Old Grizz,
Without changing anything on the bike: Set the bike on the sidestand. Search under the seat on the sidestand side of the bike to find the frame handhold. Use your dominant foot to press the center-stand pedal down until the center-stand touches the ground. It helps to have an assistant on the other side of the bike, at first, for the next step. Bring the bike upright until both feet of the center-stand are on the ground. (When you get comfortable with this step, an assistant will not be needed.) Press down with your full weight on the center-stand pedal, as you pull up and rearward with the hand on the handhold. You are not lifting the bike, you are trying to put distance between the foot pedal and the handhold. It takes practice, so keep the assistant handy at first.
You can also reduce the effort needed for the center-stand by rolling the rear wheel up on a shallow ramp, holding it there with the front brake, and then doing the center-stand trick. The ramp can be as long as you need, just so it fits between the front and rear wheels. A ramp of two inches (50mm) high should be enough help. As you gain experience in handling the bike, you can use a thinner ramp, and maybe none at all, later.
x 9714
x 4127
Re: New Member
Welcome from Pittsburgh, PA. Hope to meet you soon Dale!
Old Grizz
x 26
Re: New Member
Post by Old Grizz »
Ride Safe All
Old Grizz,
Yep I know the tricks.
I have been riding since 1970 and many different bikes.
The FJR is the worst one I have ever had when it comes to getting it on the centre stand.
I am not a small guy, I am 6ft 5 and 275 lbs.
It doesn't help that I have had 1 knee replacment and both shoulders replaced complete with rotator cuff rebuilds.
I appreciate the tips, I might have to try the little ramp for the rear wheel though.
Kind of hard to take with me on my 10000 km trip in Aug.
I have been told that the newer model FJR is easier to get on the centre stand.
I have a friend with 2021 and I guess I will have to ask him if I can give his a try.
My dealer has a 2022 on order, hmmmmm
Many improvements over my 2012.
If it's a lot easier my bank account may just take a hit.
Ride Safe
Ride Long
Picture of mine Image
mi_pjk, Cav47, and CollingsBob loved this
Re: New Member
Anyone know if a Gen III+ centerstand fits a Gen II and if it makes it much easier to use? I am OK with it but it does seem to be more difficult than necessary. I would anticipate major difficulty if I injured my left foot or had an issue with right arm/shoulder/hand.
It is almost impossible with a lowered bike (or with a flat rear tire) unless you use a ramp.
x 3519
x 12943
Re: New Member
I haven't measured the stands....... I would also say the better spring in the Gen3 rear shock will help with that.
John d
FJRModel: 2008A
x 929
x 647
Re: New Member
Post by John d »
I know the technique and it's not too bad for me to lift my '08 onto the centrestand, however, I do ride the rear wheel onto a small piece of 1/2" plywood in the garage, and that makes it considerably easier. At 68 I still have all my original body parts, (minus the blown brains cells of my mispent youth) so I guess that helps.
Welcome Old Grizz and Dale!
Re: New Member
raYzerman wrote: Wed Jun 15, 2022 11:21 pm I haven't measured the stands....... I would also say the better spring in the Gen3 rear shock will help with that.
Could be the shock/spring but I thought there was a physical difference in the stand as well. Either the leg length or possible a difference in geometry. Someone will have to try a Gen III stand on a Gen II for fit and function and report back...
x 4464
x 12609
Re: New Member
I think I recall seeing an extension for the stand that essentially acted as a lever and helped you get a bike up easier. It's been a couple years since I've seen it and I don't know if it was for an FJR, but it might prove to be something possible. Anyone else seen that thing before? Seems like it wasn't much more than a ratchet wrench or box end wrench that you just pop on when you are ready to put it on the centerstand. It gave you a much larger area to step on with increased leverage. When done, just slip it off and put it away.
It's been a while. Anyone remember seeing that?
Re: New Member
Festus wrote: Thu Jun 16, 2022 9:19 amI think I recall seeing an extension for the stand that essentially acted as a lever and helped you get a bike up easier. It's been a couple years since I've seen it and I don't know if it was for an FJR, but it might prove to be something possible. Anyone else seen that thing before? Seems like it wasn't much more than a ratchet wrench or box end wrench that you just pop on when you are ready to put it on the centerstand. It gave you a much larger area to step on with increased leverage. When done, just slip it off and put it away.
Festus,
I remember. Not sure about using tools, though. Seems like the right diameter and length of iron pipe would do the trick nicely, there.
Steel_Gin
FJRModel: 2012 FJR1300A
x 1428
x 446
Re: New Member
Post by Steel_Gin »
A little late to this but welcome. I have a 2012 as well and it got a lot easier to put on the center stand when I put on a new shock. The OEM shock was a bit more tired than I realized.
x 1388
x 666
Re: New Member
Hey guys don't know how i missed this but welcome from the Big Apple. :D
CollingsBob
FJRModel: 2024 BMW R1300 GS
x 6412
x 2794
Re: New Member
Post by CollingsBob »
Welcome Dale_I
I hope you enjoyed CFR2022!
