*FIXED* fuel filler lock stuck/frozen
wpbfjr
FJRModel: 2006 manual shift
x 12
x 100
Post by wpbfjr »
hi,
servicing my 2006 fjr, the fuel fill door lock is stuck/frozen.
don't wanna break a key, placed white lithium on key, inserted into keyway, no joy...
presuming the actuating lock on underside and inside tank has crud on it, tried to take fuel fill door off, no joy as door MUST be open to remove 1 retaining bolt.
uugh...
anyone had similar issue?
any ideas, other than complete new fuel tank?
tia,
dana
signature lost in the mail...
Re: fuel filler lock stuck/frozen
You'll need something penetrating, a creeper. PB Blaster, Kroil, TriFlo, even WD40 might help. And try pushing down on the lid really hard while wiggling the key.
And just to be sure, a stoopit question.... you sure you have the right key? Have you tried more than 1 key? Not being insulting but if you ever dealt with my wife, you'd know why I have to ask such things.
wpbfjr
x 12
x 100
Post by wpbfjr »
rbentnail wrote: Tue May 10, 2022 6:51 pm And just to be sure, a stoopit question.... you sure you have the right key? Have you tried more than 1 key? Not being insulting but if you ever dealt with my wife, you'd know why I have to ask such things.
same key started fjr moments earlier...
have original factory key hidden on bike, will try that one... thanks
your wife could be kin to lisa w/iron butt... she bails out riders IBR thinking they've lost something, but hadn't
x 12310
x 11257
Remove the whole assembly #24 by removing the screws #25/#26 that hold it to the tank. see what is happening on the backside.
You can likely break the latch mechanism free from the back it probably isn't the lock cylinder that is stuck but rather the latch assembly.
https://www.yamahapartsnation.com/oempa ... /fuel-tank
John d
FJRModel: 2008A
x 929
x 647
Post by John d »
I would first try a lock deicer/lubricant.
wpbfjr
x 12
x 100
Post by wpbfjr »
FIXED!!! factory key, pb blaster, pressing VERY firmly down allowed the latch to retract after several tries.
fully disassembled and cleaned mechanism...
reassembled and works like kinda new...
thanks all.
dana
Cav47, rbentnail, bigjohnsd and 3 others loved this
Re: *FIXED* fuel filler lock stuck/frozen
Awesome! One I hadn't heard of.
