Driveshaft Vent Cap
x 47
x 566
Driveshaft Vent Cap
Post by Canadian FJR »
Can this vent cap be removed (and reinstalled) without damaging anything.
If so, how to remove it?
CollingsBob
FJRModel: 2024 BMW R1300 GS
x 6412
x 2794
Re: Driveshaft Vent Cap
Post by CollingsBob »
Why would you want to remove it?
x 914
x 2671
Other sandbox. Unfortunately no pics but apparently easy to break the cap off the part that goes into the drive so you would probably end out replacing it. Not expensive.
https://www.fjrforum.com/threads/rear-o ... nt.172236/
x 47
x 566
Thanks Ross
Cleaning up the ‘03 and the original one is a bit tarnished
x 914
x 2671
Yes. The one on my '07 was a bit pitted and corroded but I never bothered to do anything with it.
Service manual doesn't say anything about removal or installation as far as I could see. I only remember the one post about someone replacing it.
x 3431
x 12686
You'll break it trying to get it out. Normally they're pressed in, cap will come off and never stay back on... whole new vent if you go down that road.
x 914
x 2671
raYzerman wrote: Fri Feb 11, 2022 7:46 am You'll break it trying to get it out. Normally they're pressed in, cap will come off and never stay back on... whole new vent if you go down that road.
Not a big deal - they aren't especially expensive. Same one is used on a bunch of Yamaha shaft drives. They do seem to pit and corrode. Purely cosmetic, of course, but I was tempted to replace the one on my '07 when I found it couldn't be cleaned up. The one on my 2011 is starting to look like that...
Since it is a friction fit, I would probably throw the breather cap in the freezer for a half hour before tapping it into place.
x 914
x 2671
Duplicate post!
x 3431
x 12686
Just paint the damned thing silver. Done! Or how about just leave the saddlebags on. Done!
x 47
x 566
Potty mouth 😂
Steel_Gin and raYzerman loved this
