Cruise Control inop Gen III
- FJRModel: 2015
- x 2
Anybody ever have a flashing cruise control indicator? Mine did this on a short ride today and the cruise control wouldn't engage. The owners manual states that if any system on the bike has a problem the indicator will begin flashing and cruise will not engage and recommend a visit to the dealer.
Thoughts?
Thoughts?
- x 3523
- x 12948
Re: Cruise Control inop Gen III
First, there is a recall for the front brake light switch... get that done. No trip to the dealer needed except that....
Stuff you fix yourself......
Other causes, ABS sensors on the wheels can get corroded, clean the hole they go in and any aluminum corrosion that may have transferred to the sensor. Coat the hole and the plastic adapter of the sensors with silicone grease and reinstall.
Go into DiAG and look for error codes related to the sensors and clear the codes.
Other issues.... sticky rear brake pedal will cause the brake lights to stay on... common FJR problem, grease the rear brake pedal pivot.
Clutch switch can also get a bit of crud in it preventing full extension of the plunger.. spritz with contact cleaner should flush it out.
- FJRModel: 2015
- x 2
Hey thanks for all that info as it makes me feel better that it may be something I can correct. Also didn't know about the front brake light switch recall or that I could pull codes. I'll have to look that one up as to "how" it's done.raYzerman wrote: ↑Thu Sep 23, 2021 9:21 pm First, there is a recall for the front brake light switch... get that done. No trip to the dealer needed except that....
Regards
- jwilly
- Site Admin
- x 2249
- x 2148
Never trust a guy from Canada who tells you to clean your hole..
Happened to me once and my rear brake pedal was the culprit.
- x 4512
- x 2296
Me too but I don't remember if the CC light flashed when it refused to engage.
- x 3523
- x 12948
The front brake lever switch can also be given a spritz of contact cleaner to ensure its plunger is moving freely as well.... the new switch is alledgedly more robust.
- x 4465
- x 12617
My '13 does it from time to time. Works perfectly all day and then in an instant, while moving along, the light starts flashing and it stops working. Turning the bike off and on again fixes it every time. I've lubed the brake lever, and looked at stuff while apart and never seen any issues. One day, when I have time, I'll dive deeper and figure it out.
- Bounce
- x 7974
- x 3775
Probably covered but check the following R&R with a clean and lube:
1. Hand lever pivot points. There are brass bushings that are wear items and can affect CC if not replaced. Cheap and easy to do (inspect, clean, lube) 1 or 2 times a year.
2. Foot lever pivot points annually. These are part of the routine maint call out in the owners manual for the same reasons as above.
3. R&R and clean the contacts (CRC contact cleaner) on the micro switches in 1 and 2 as well as the side stand lock out switch.
- x 4512
- x 2296
I have wished for a brake light on the dash but been too lazy to wire one. Would serve as notice when/if a brake switch is stuck, or if one is dragging the brake. Both of my cars have a cartoon image of the car in center of the dash which animates the brake lights when applied. Interesting but almost useless because it requires too much of the driver's attention to notice.
One rider I am often following aggressively uses engine braking so he slows quickly without a brake light. Gets grumpy when asked to drag a brake at the same time to illuminate his brake light. Gripes when I "won't keep up" riding a safe distance back knowing he suddenly slows to play with his phone or look at dogs in yards.
- mcatrophy
- FJRModel: 2018 FJR1300AS
- x 60
- x 664
Not quite that simple. The brake switches are each double pole. With a sticky switch it might be that one contact is activated, the other not. Simply monitoring the brake light may not give you the full story.
It's quite a complex system. As far as I can tell one circuit is used mainly for the brake lights, the other with an interlock mechanism. Both are monitored by the ECU, so either might cause it to throw a wobbly.
And be aware the contacts are made when the levers are relaxed, broken when the brake lever is activated.
My web site
- x 4054
- x 6947
My 13 did that. It was the the switch on the bars. A little squirt, little adjustment, good to go.
- FJRModel: 2015
- x 2
All interesting replies here guys. Without doing any of the aforementioned suggestions I continued riding and have only had this happen one more time. It was probably because I hadn't ridden the bike in months due to heart issues and I've now ridden perhaps a dozen times since posting. Oddly enough when I started the bike and allowed it to warm up while I geared up it produced the most god awful smell I'd ever smelled. Kinda a mix of electrical and animal fur.
Now I've seen a chipmunk on the patio and in the carport so I figured one may have nested on top of the exhaust pipes below the engine causing the smell. I'm thankful the bike didn't go up in flames like his little ass may have! Anyway I will now dedicate some time to preventive maintenance and a oil change. I was just so happy to be able to get out and ride again. Thanks guys for the replies.
- x 4512
- x 2296
Have had CC fail to engage once this year. Remembering the front brake light switch recall I pushed the front brake lever forward then the CC resumed function.
