Installed Shorai battery on 2006 Gen2, KrZy8.
Immediately noticed decreased max volts on voltmeter.
AGM battery always 14.1 to 14.3, base load.
Shorai immediately dropped to 13.7 -13.9, same base load and ambient temps.
Even substituted AGM battery for Shorai, and yep, back to 14.1 to 14.3.
Base research shows that *some* Li batteries (for motor homes, other bigger applications) have a circuit internal to Li battery which effectively disconnects RR output to keep volts in the Li battery 'sweet' (lower) regions.
Any ideas oh great FJR pundits?
Shorai battery - reduced charging Volts?
Forum rules
- x 122
- x 1647
- x 4511
- x 2296
Re: Shorai battery - reduced charging Volts?
It can not be that the internal BCM disconnects "to keep volts lower". If it did then the R/R voltage would rise to its nominal 14.2V for lack of load.
For the R/R to be held down to 13.8 the Shorai must be loading the circuit. The 0.4V must be going to heat somewhere in the battery.
No matter, 13.8v is a good healthy fully charged lead-acid voltage. Worry more about the engine off voltage.
- x 122
- x 1647
Yes, fully charged with appropriate Li battery charger. Good point, I forgot to mention it.
- x 122
- x 1647
Agreed 13.8 is good, just used to seeing 14.x all the time. Install Li and boom, down to 13.8, got me curious.N4HHE wrote: ↑Fri Jul 09, 2021 4:06 pmIt can not be that the internal BCM disconnects "to keep volts lower". If it did then the R/R voltage would rise to its nominal 14.2V for lack of load.
I do see that RMSTATOR and RicksMotorSports https://ricksmotorsportelectrics.com/Re ... le-14_420 make Li specific RR to reduce charging volts to Li batteries.
Just for grins and giggles, I'm going to install a new to me from RoadsterCycle RR on the 06 and see what happens. Will also measure ACV from stator to ensure all is healthy there.
- x 122
- x 1647
