EZPass mount
- Steel_Gin
- FJRModel: 2012 FJR1300A
- x 1425
- x 446
EZPass mount
New York state has gone cashless for their toll collecting and has completely messed up my system to get my Ezpass to read consistently. In their "wisdom" or wis-dumb, rather than leave the readers that were already in place at the toll plazas they are taking them down and have installed readers (spent 100s of Millions dollars) over the Thruway to read your pass going 65 mph. I have the pass mounted to my left forearm and what I had been doing when passing slowly through the plaza is stick my arm out and it would read every time. Because of traffic there has been a few times I have not stuck my arm out as I pass under the readers at speed, resulted in no reads and I got charged a toll. (I have a plan that I can travel on the Thruway for free for the first 30 miles.) My license plate is register on my account with the tag I am using; So, the stories of reading your plate and it charging your account accordingly to completely false. I have the statements to prove it. I am surprised that it doesn't read consistently since it sits facing up on my forearm but that's a different discussion.
What have others been doing to mount their EZPass? Has anyone tried making something that would utilize the unused mirror mount on the left handlebar next to the clutch reservoir? As much as I don't want to do it I have thought about mounting it at the bottom of the windshield using the plastic Velcro they supply with them. What I think might happen is the wind will pull it off. Has anyone here done this and how well did it hold? Since there is a slight curve to the windshield I think the Velcro might not fully seat to give it a solid hold........plus I really don't want to get into remembering to pull it off and on. For sure I am going to forget and the thing is going to be stolen or forget to put it back on.
- x 4348
- x 2236
Re: EZPass mount
Riverpass reads a $0.50 RFID tag affixed to the inside of windshields of my cars and truck. Well, I exaggerate. That is the 100 piece price. Thousands are throw-away cheap. Researched this for scoring motorcycle races.
That you get charged for their misreads is deliberate incompetence on their part in their favor.
Riverpass has failed to read my RFID tags but knows the license plates on my account so they billed exactly as if they had read the chip. Do not have one on FJR. No plans on crossing the Ohio River on I-65 at KY/IN.
edit: speleeng.
edit: speleeng.
Steel_Gin loved this
- Brodie
- FJRModel: 2008 Advanced Edition
- x 165
- x 170
Re: EZPass mount
Duct tape it to the top of your helmet.
Brodie
Brodie
El Toro Joe, Jalingo, Steel_Gin and 2 others loved this
Amateurs: - With Godâs Blessing - built the Ark.
- Brodie
- x 165
- x 170
Re: EZPass mount
Just donât cover the bar code, they need to read it at speed.
Brodie
Brodie
- x 4139
- x 4636
Re: EZPass mount
If my pass is not read, my account gets charged anyway because they pull it up by plate, at least for tollbooth passes.
My transponder is mounted on the beak of my bike. Readers in my area have gotten better. The tollbooth readers failed to read my transponder, regardless of location, about 1/4 of the time. Velocity may have been involved⌠Express lane readers, so far, have a higher read rate, for me.
âEverybody wants to be a gangster until itâs time to do gangster shitâ -Helen Keller
- x 2892
- x 3091
Re: EZPass mount
I mounted mine on top of the clutch reservoir. Used 3m velcro hanging tape (for hanging pictures). It comes off without leaving any residue. I also put a little velcro strap around it to keep it extra secured. When traveling around Chicago it read all 4 times when I drove under the express lane readers. Not sure how those readers compare to the ones where you are. It is securely fastened, but not sure how convenient it would be as a daily driver to put on and remove.
- FastPappy
- FJRModel: 2009 AE
- x 1370
- x 649
Re: EZPass mount
I do have mine mounted on the windshield with velcro the only problem I've had is when I used to commute and constantly removing it for security the velcro would wear out and need to be replaced. Never had a problem with wind but bumpy roads when it was warn out could knock it loose. One time coming home over the VZ bridge hit a bump as I approached the plaza and it came off. Couldn't stop so rode over to a manned booth and explained what happened to the toll taker who actually walked out and retrieved it for me. I check it often now and haven't had a problem since.Steel_Gin wrote: âSun Jun 13, 2021 9:53 pm New York state has gone cashless for their toll collecting and has completely messed up my system to get my Ezpass to read consistently. In their "wisdom" or wis-dumb, rather than leave the readers that were already in place at the toll plazas they are taking them down and have installed readers (spent 100s of Millions dollars) over the Thruway to read your pass going 65 mph. I have the pass mounted to my left forearm and what I had been doing when passing slowly through the plaza is stick my arm out and it would read every time. Because of traffic there has been a few times I have not stuck my arm out as I pass under the readers at speed, resulted in no reads and I got charged a toll. (I have a plan that I can travel on the Thruway for free for the first 30 miles.) My license plate is register on my account with the tag I am using; So, the stories of reading your plate and it charging your account accordingly to completely false. I have the statements to prove it. I am surprised that it doesn't read consistently since it sits facing up on my forearm but that's a different discussion.
bigjohnsd and El Toro Joe loved this
- x 11601
- x 10809
Re: EZPass mount
I had mine mounted to the inside of the FJR windscreen using the 3M DUal Loc Tape that came with my NY EZPass - never had a problem.
EZ Pass doesn't work around Denver, but if you ride real close to either the edge of the lane - the center edges work especially well, the cameras can't read your license plate. I've used the C470 bypass numerous times with no charges ever received. YMMV
PhilJet09 loved this
Re: EZPass mount
I have had EZ Pass for about 15 years. I got the interior device which almost always worked with my car and mostly worked with my motorcycle. The EZ Pass is an active device, it's powered to deliver a signal to the toll booth reader, which makes it a flexible use device.
At ~8 years I had to have my pass replaced due to battery life, with about the same effectiveness as the first pass. When they started high speed drive-thru booths my pass stopped working from my motorcycle. No matter the pass placement, orientation or my lane placement my pass would not be read. The same became true for the new gantry tolls over the road. My friends with a (big, ugly) Pass mounted to their bikes have zero problem. But, being affixed to the bike means that it can't be shared with my car. Not that EZ Pass would intentionally put you in a position where you MUST have two or more passes.
The good news is that my EZ Pass account was still billed without penalty. Looking at my EZ bill, if the Pass was from my car the billing showed the Pass S/N, if it was my bike it was billed to the license plate number. The only time I ever had a problem with my bike was in NJ at a gated booth. No read, no raise the gate. I created a major traffic jam while the toll taker tried to sort out why my valid Pass wouldn't raise the gate.
In some areas, especially in the south east the toll transponders are a passive RFID device that responds to a ping from the toll booth. Mounting these devices have some detailed specifications. Only the SunPass Pro is portable between vehicles.
- FastPappy
- FJRModel: 2009 AE
- x 1370
- x 649
Re: EZPass mount
The EZ Pass for my bike is motorcycle specific. Different charges and discounts related to motorcycles as far as I know.
- x 4348
- x 2236
Re: EZPass mount
Riverpass at I-65 KY/IN uses passive inexpensive RFID tags and is pretty free about issuing multiple per account. I have 3.
Re: EZPass mount
Made me look. The only discount NH offers is for commercial use and daily commuters. NH E-ZPass says the interior and exterior passes are suitable for motorcycle use. Only the interior pass doesn't work for motorcycles. My EZ account does correctly show my Motorcycle as a MC pass.
- FastPappy
- FJRModel: 2009 AE
- x 1370
- x 649
Re: EZPass mount
Guess it's area specific but I'm pretty sure bikes are charged a lower rate than cars, trucks etc. But they get you coming and going. (Pun intended).
- Steel_Gin
- x 1425
- x 446
Re: EZPass mount
My tag is motorcycle specific and charged at a cheaper rate than four plus wheels.
I like the idea of mounting on the clutch reservoir with the 3M Dual Loc Tape.
What size are the threads and how deep is the mirror mount on the clutch reservoir? I'd like to play and see if there is something I can make to utilize that.
- Snowflake
- FJRModel: 2014ES
- x 6
- x 92
Re: EZPass mount
Mine is on the inside of the windshield, almost at the bottom. Used some heavy duty Velcro adhesive strip. Been there for years, works fine.
- mcatrophy
- FJRModel: 2018 FJR1300AS
- x 60
- x 661
Re: EZPass mount
Thread size: Diameter 10mm, pitch: 1.25mm. Be aware it's not threaded all the way down, the threaded depth is something like 15mm.
Please note, my bike is the YCC-S variant, but I'm pretty sure the sizes are the same throughout.
Easy enough to pull the plastic plug and see: (click on image for larger view)
You can use a brake calliper bolt to check the thread size:
Used it for my satnav and heated vest controller mount:
My web site
- x 4
- x 92
Re: EZPass mount
I had mine on the inside of my windshield. I too had the NY M ezpass. It Always read. The tollbooth cameras were dependent on bike width believe it or not, so they read much better when the saddlebags were on. I'm pretty sure I've always had the high speed ones read too. I used dual-lock for that. YMMV though, I hit a railroad crossing in Indiana doing roughly 60 mph.. wheels stayed on the ground, no extreme hit to the suspension.. but the EZ pass decided to vacate the premises. Turn around was 1.5 miles down the road, and I'm sure EZ pass is going to ding me for damage when I have to turn it back in.
- FJRfarrier
- FJRModel: 2012
- x 1554
- x 2192
Re: EZPass mount
I kept mine in a mesh drawstring pouch that was ziptied to the dash shelf. I didn't like the idea of trusting velcro or sticky tape. And the pouch also allowed me to take it out when I didn't need it.
Even without the dash shelf, could possibly come up with some way to attach the pouch to the bike if needed.
I havenât made any really bad decisions lately... Iâm getting bored.
- FJRModel: 2014 ES Red
- x 5
- x 26
- FJRModel: 2019
- x 125
- x 217
Re: EZPass mount
Mine lives in the glove-box. I've never needed to take it out; always seems to work through the lid. If I get concerned or want to be overly careful, I place it in the top pocket of my tank bag.
No issues yet.
No issues yet.
