Garmin GSM 30 antenna lead?
- griff
- x 266
- x 756
Looks like the antenna lead from my GSM 30 XMRadio puck to my gps is shitting the bed. I replaced this a million years ago, but can't seem to find one out there anywhere. I would even take a GSM 30 non functioning puck with the intact lead if any one has it. Taking a chance posting this on Friday that the threadshitters will jump in.
- BikerGeek
- x 5348
- x 4705
Re: Garmin GSM 30 antenna lead?
I have one laying around somewhere that I'm not using any more. Perhaps we can work out a deal...
One thing to consider - from what I recall, the subscription is tied to the ID on that specific puck, right? Can you transfer your subscription?
ETA: You're talking aboot the Garmin GXM30 SiriusXM satellite antenna, right?
- griff
- x 266
- x 756
Thanks Geek. What I really need is just the lead from the puck. It can be disconnected and swapped to another puck. Yeah, if I change the whole puck I need to change subscriptions. I just changed GPSs and it seems to work ok, but the lead going into the puck is still pretty rotted and should be changed.
- x 47247
- x 20078
- griff
- x 266
- x 756
I knew it.
- Red
- FJRModel: 2008 FJR1300ABX
- x 222
- x 1217
Griff,griff wrote: βFri Jun 11, 2021 12:00 pmThanks Geek. What I really need is just the lead from the puck. It can be disconnected and swapped to another puck. Yeah, if I change the whole puck I need to change subscriptions. I just changed GPSs and it seems to work ok, but the lead going into the puck is still pretty rotted and should be changed.
You may be able to sheath the old cable with heat-shrink tubing, to extend its' life. Some heat-shrink tubing will reduce (shrink) by 50% with heat, some will shrink by 30%. Specify which type you will want, when buying.
If you are not able to find a good cable, then I would try to find the correct connector, into the GPS. You may be able to use some existing cable, such as phone cord or similar, and simply add the correct connector, then connect to the puck. You may need to construct the cable itself, either braiding or twisting the wires (like a rope) to keep it flexible, or use bulk ribbon cable. Heat shrink tubing (with or without the internal hot-glue) will make the job look professional.
HTH.
- griff
- x 266
- x 756
Thanks Red. I did wrap the connector right at the puck, this is where the issue is. Plugged in another GPS and it worked. At least for now. The connector into the Garmin 550 is actually a min B USB connector, so that could work if I had to.
- BikerGeek
- x 5348
- x 4705
Ah. Gotchya.
- Red
- x 222
- x 1217
Griff,
Better and better. You can start with any good USB cable with the correct plug, and simply wire the far end into the GPS puck.
A bare mating connector will make it easier to trace the wiring in that tiny USB connector on the new cable.
- Red
- x 222
- x 1217
- John d
- FJRModel: 2008A
- x 926
- x 647
Griff.
I have a good fully functioning GSM30. Yours for shipping cost.
- griff
- x 266
- x 756
