Spokane, WA area service
- FJRModel: 2012
I moved to near Diamond Lake, WA (USA, Zip 99156, North of Spokane) and wonder if anyone has recommendations for a reputable mechanic for servicing my 2012 FJR. I do the general maintenance myself (oil, lube, tires, brakes, etc.) but often prefer to let someone else dig in to do more involved service.
- x 4539
- x 6188
Re: Spokane, WA area service
Allsport completed the transmission recall on my 17 ES. Other than over tightening the oil drain plug, lower fairing bolt and the oil filter, I have had no problems. They did the work on time as promised. I suppose I will find more bolts too tight when I do more maintenance and if that is the extent of the problems I find I am thrilled.
Auburn loved this
- x 3430
- x 12679
Well...... there is this annual event called a tech day in Auburn..... not sure when the next one is, but if you hang around with those knowledgeable dudes, you will learn somethin' and they'll help you get done what needs doing.
- Auburn
- FJRModel: 2006
- x 2252
- x 1410
WIll be next year do to the unpredictability of our Governor and his Covid policies. I have a lot of travel going this Fall, so I can't do it then. Probably be around the end of April, first week in May depending on how bad winter is so the east side folks can get across the mountain passes.
get out and ride! IBA #54706
