2021-01-06 KZ1300 runs perfect and...
x 1614
I can't say the rest of what happened today in our capital...
So let's stick to a 42 year old KZ1300 ride, ok?
I know most don't 'Get This.'
And that's OK. I bought this bike new. Actually took a loan out from a bank for it. And, as you who personally know me, I'm a 'cash on barrel head' guy.' No debts, no liabilities.
But, 42 years ago I took the plunge..
And the B I T C H still rides..
(BTW, the bike not me, f@$k heads!)
Uncle Hud, CollingsBob, Hppants and 1 others loved this
x 47363
x 20109
Re: 2021-01-06 KZ1300 runs perfect and...
Saweet!
Awesome run through the gears....thanks for that treat!
fjray
FJRModel: 04
x 217
x 1207
Post by fjray »
The old Bitch sounds happy.
x 1614
fjray wrote: Thu Jan 07, 2021 1:16 am The old Bitch sounds happy.
well, uh, you see I stole the audio from some other guys clip.... but she sounds just like that! :lol:
x 47363
x 20109
dcarver wrote: Thu Jan 07, 2021 1:17 pm
Fooker. Fake video...I never suspected you to stoop so low. :nhlfight:
x 15301
x 14209
If that is what she sounds like, ya done well Carver.
That is a nice bike.
x 3766
x 5927
You could storm the capital with that thing!
x 12281
x 9233
Hppants wrote: Thu Jan 07, 2021 2:06 pm If that is what she sounds like, ya done well Carver.
You mean well done Ray. Carver just rides the things that FJRay fixes and builds! Lol. Kidding. Am sure it was a joint effort.
It is cool for sure. That bike is almost as old as me!
wheatonFJR and fjray loved this
fjray
FJRModel: 04
x 217
x 1207
Post by fjray »
I don't know that I would want to do another one. That engine is one of the most complicated I've done. I'm glad to see Don is getting the fine points worked out.
x 1614
She has issues.. beyond the scope I asked Ray to address..
This POS bike never was 'excellent'.. Burned oil from day one, big K said f@$k You.. Under supplied, voltage wise..
BUT! Making progress.. Ricks Electrics has modern rectifier/regulators. Noticed to day the voltage values are all over the terrain.. 15.1 to 12.1 for no apparent reason.
Good news is...
See a newer post..
x 3436
x 12712
Ah yes, the Honda regulator issues as I discovered on the VFR... If you haven't already bought a Rick's, might I suggest you get a genuine Shindengen mofset.... FH020AA's can be had used from FJ-09, FJR and other Yamahas, then either buy a harness from Roadster Cycle (he sells new Shindengen's too), or make your own if you buy the connectors. Of course, do a quick check of your stator with your multimeter first.
x 1614
raYzerman wrote: Thu Jan 14, 2021 10:06 am Ah yes, the Honda regulator issues as I discovered on the VFR... If you haven't already bought a Rick's, might I suggest you get a genuine Shindengen mofset.... FH020AA's can be had used from FJ-09, FJR and other Yamahas, then either buy a harness from Roadster Cycle (he sells new Shindengen's too), or make your own if you buy the connectors. Of course, do a quick check of your stator with your multimeter first.
Just wondering...this is a kz1300 kawasaki... same regulator as mentioned above?
x 3436
x 12712
It does not matter which bike... stators and regulators have the same circuitry as wired into the bike. The mofset type is a huge upgrade over the old style. The three stator wires go in one side, and the power and ground go into the other side (ensure correct polarity there!). Roadster cycle's harness will fix you right up.
