FJR Brake Light Switch Recall
x 3430
x 12679
Many have had issues with intermittent cruise engagement..... 2013-up.
Recall issued for Canada....
https://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/ ... esult&pg=0
x 3979
x 6902
Re: FJR Brake Light Switch Recall
Yup, just got mine today.
The issues i had with the cruise were caused by my bike being hissy after being paraded around the country on a trailer. Well, that and a pretty routed wire.
Madmudder
FJRModel: 2014 FJR1300es Metallic Black
2023 FJR1300es Cobalt Blue
2022 Honda Goldwing tour DCT Blue
x 1853
x 381
Post by Madmudder »
No Stock for part but I have no intention on taking it to the dealer before spring anyhow. I did speak to the dealer about taking mine off and giving it to them for the updated switch but they said they had to do the work. I said no problem i'll supervise the work when it is being done in the spring.
2014 FJR1300es
x 47
x 566
Post by Canadian FJR »
Received my letter today.
Hack
x 1079
Post by Hack »
Canadian FJR wrote: Tue Dec 29, 2020 1:43 pm Received my letter today.
Received mine earlier this week... That's two letters in as many weeks.
'Wouldn't it be easier for Yamaha to just give us all new bikes..? :D
Madmudder, HotRodZilla, Intech and 2 others loved this
blind squirrel
FJRModel: 2014
x 1533
x 2582
Post by blind squirrel »
December 28, 2020 NHTSA CAMPAIGN NUMBER: 20V814000
Front Brake Switch Can Fail
Failure of the front brake switch can cause the brake light to stay on constantly and/or the cruise control system to shutoff unexpectedly. Both situations increases the risk of a crash.
NHTSA Campaign Number: 20V814000
Manufacturer Yamaha Motor Corporation, USA
Components EXTERIOR LIGHTING
Potential Number of Units Affected 18,203
Summary
Yamaha Motor Corporation, USA (Yamaha) is recalling certain 2018-2020 MTT9GT (Tracer GT), 2019 MXTGTKL (NIKEN GT), 2017-2020 MT10, 2018-2020 XTZ12 (Super Ténéré), 2013-2020 FJR13, 2018 XV19B (Star Eluder), and 2018-2021 XV19 (Star Venture) motorcycles. The front brake switch can fail due to increased resistance from silicon oxide.
https://www.nhtsa.gov/recalls?nhtsaId=20V814000
Burnspot
FJRModel: 2020 Super Tenere
x 428
x 953
Post by Burnspot »
Just got a phone call this morning, from the dealer I bought the bike from. Wanted me to let them know when I'd be by as the parts are in-stock with Yamaha, but have to be ordered. 2015 ES
Scott
https://burnspot.smugmug.com/
x 1419
x 3452
Guess I have to look into this.
huron52
x 101
x 308
Post by huron52 »
I didn't get my letter....... oh never mine. I figured it out.
czimmer
FJRModel: 2015 FJR1300A
Post by czimmer »
This still seems to be a bit of a mystery on what exactly they are replacing. In the other sandbox, one member was told it was a 2 hour job and the front wheel had to come off. But everything I read points to the switch itself which should be a quick swap. I sent an email over to the UK FJR club to see if they have some more insight on this. My 2015 has parts coming in for the brake light switch but I have not been overwhelmed by the service at this dealer (not a lot of options) which is why I have been doing the service myself to date.
IBA# 78859
2015 Yamaha FJR1300A
2001 Honda ST1100A (wife's)
2002 Honda ST1100A (daughter's)
x 3430
x 12679
Have looked at the Korean procedure.... FYI, the parts diagram does not show the switch has an attached harness which is connected up in the nose of the FJR.... so windshield and nose trim has to come off to access the connector, dash panel off to be able to snake the harness up into the nose, undo the wire retainer on the underside of the right handlebar...... 0.9 hrs. labour.
No front wheel removal required, nothing being done down there.
HotRodZilla and N4HHE loved this
czimmer
Post by czimmer »
raYzerman wrote: Thu Jan 28, 2021 9:50 am Have looked at the Korean procedure.... FYI, the parts diagram does not show the switch has an attached harness which is connected up in the nose of the FJR.... so windshield and nose trim has to come off to access the connector, dash panel off to be able to snake the harness up into the nose, undo the wire retainer on the underside of the right handlebar...... 0.9 hrs. labour.
Sigh...yeah. I'll have a chat with the service manager. The last time my bike was there they used a power drill to install the allen bolts to the dash and almost scratched the plastic on the gauges but cracked the dash plastic (I replaced it when I did the valve check). It's been a long time since I've been there so maybe that tech isn't working there anymore. I have also found missing parts such as the plastic clip that goes over the fuel connector but I don't know for certain if that was the dealer or the factory. Again, I fixed that myself. Not crazy that they are now going to remove the windscreen...
IBA# 78859
x 1419
x 3452
Just got a call from the dealership I bought from. Parkersburg, WV. Yeah, not taking it there.
BigRock
FJRModel: 2014 FJR1300ES
x 2
x 2
Post by BigRock »
I replaced mine in 2017. I paid for part and did it my self. Cruise wouldn’t engage and brake light on all the time. Took longer to remove panels than to replace the switch and harness, all one part.
Recall notice came about a month ago.
Niehart
FJRModel: 2015
x 4353
x 385
Post by Niehart »
Bigrock, I would guess it's a new part number from the one you replaced. If it's the same part number you are good. Well except for the time and money spent.
BigRock wrote: Fri Apr 02, 2021 11:41 pm I replaced mine in 2017. I paid for part and did it my self. Cruise wouldn’t engage and brake light on all the time...
I was one of the first FJRiders to have a TPS failure and report it to a dealer. I had a long discussion with a Yamaha dealer and explained what I found and linked him to the other sandbox where I had posted a troubleshooting guide for the TPS and an autopsied TPS that showed the failure mode. On October 16, 2006 Yamaha issued Recall No. 06V371000 for the TPS. Later, when I was at the dealer for another issue I mentioned that is sucked that I paid for a new TPS and did the work my self, and then a recall was issued. The dealer told me that if I still had the part I just needed to give it to him and he would refund the cost. I told the dealer it was in pieces due to doing an autopsy. He said it didn't matter, just bring him the parts. I did, and he paid me. Done, simple as that. This dealer was extremely helpful on several issues. So of course he had to close.
BigRock, if you still have the part try talking with a dealer, you may get a refund. The brake switch is really expensive for just a switch, a little wire and a connector.
BigRock and wheatonFJR loved this
griff
x 266
x 756
Post by griff »
f@$k it with my bike. If it ain't broke, don't fix it. 7 years, 145k miles - no problem. I wouldn't trust the morons here in Greenville to do it right anyhow.
wheatonFJR and Intech loved this
x 4353
x 2239
I’ve had CC drop and not re-engage during the past month. Turned CC off and on, no luck. Turned ignition off (at 60 mph), no luck. Applied front brake, CC function resumed. Happened another time several years ago and was totally dumbfounded then it started working again. Used similar “diagnosis” then before the recall.
Have learned my dealer ordered kit under my VIN then installed on a squeaky wheel. I’ll be talking to the North American Yamaha distributor Monday.
Guess it is good news https://www.yamaha-dealers.com/public/w ... tions.html doesn’t list my recall as being completed.
