I haven't been keeping up.Recalls on an 18
fencer
FJRModel: 2006 *SOLD now 2018
x 215
x 274
Post by fencer »
Any recalls out there?
x 1716
x 2627
Re: I haven't been keeping up.Recalls on an 18
Not sure, but I think there may be one on that damned knuter valve!
fencer loved this
fencer wrote: Wed Sep 30, 2020 6:10 pmAny recalls out there?
Fencer,
You can call the Yamaha mothership directly (1-800-962-7926), give them the VIN,
and they will check to see that all factory recalls are done for your bike.
:mrgreen:
fencer and wheatonFJR loved this
N4HHE and Intech loved this
x 3044
x 3261
Clearcoat didn't take.
Just kidding. Looks real good in person.
Not that Yamaha has divulged.
fencer wrote: Wed Sep 30, 2020 6:10 pm Any recalls out there?
x 4520
x 2296
What has there been for any in a long time? The 2016 has an issue with attempting to start with ignition key not fully in 12:00 o'clock generates a CEL which requires an OBD-2 scanner to clear.
x 6243
x 10419
N4HHE wrote: Thu Oct 01, 2020 3:16 pm What has there been for any in a long time? The 2016 has an issue with attempting to start with ignition key not fully in 12:00 o'clock generates a CEL which requires an OBD-2 scanner to clear.
Thinking back I don't remember a single recall on my 2013.
If there was one I missed it.
Do later model FJRs have many recalls?
There weren’t any on my 14. None so far on my 18. A bunch of bike surfing tards like us would have dissected and regurgitated any recall ad nauseum.
N4HHE, Uncle Hud, danh600 and 2 others loved this
The last FJR recall was 2011. The front brake switch would not turn on the rear brake light. It was caused by a defective switch which was installed on some bikes over a period of a few months. Previous to that was 2009 for the ignition switch and ground connector.
In 2013 there was a technical service bulletin for the check engine light.
x 12959
I am only aware of the TSB for the Check Engine issue with the 2016, solved by with a reflash by the dealer.
Well, we have missed a most excellent opportunity to f@$k with Fencer. Couldn’t someone have dreamed up a list of four or five ridiculous recalls?
In a way, I’m disappointed.
Cav47, HotRodZilla, and wheatonFJR loved this
x 12959
Well, I am told the torque spec for the oil pan drain bolt is 31 ft. lbs.......
fencer
x 215
x 274
Post by fencer »
raYzerman wrote: Fri Oct 02, 2020 10:40 pm Well, I am told the torque spec for the oil pan drain bolt is 31 ft. lbs.......
i would not have to worry about that.
I never change the oil
Uncle Hud, HotRodZilla, and wheatonFJR loved this
