Stupid clutch lever question
I am OCD, and I pull pegs and levers several times a year and clean and lube them. They get crunchy fast riding in wet weather.
Today, when I pulled my clutch lever, the bushing (?) was gunmetal blue on one side. Not the brass cylinder, but the collar that’s pressed into the lever, the one that doesn’t come out.
The blue wouldn’t come off. Not green copper fouling, this is deep blue, and wasn’t going anywhere.
Not a cause for alarm, but I’ve never seen this before. Have you guys seen this?
Bounce loved this
x 2442
x 3278
Re: Stupid clutch lever question
I pulled mine just the other day to install a new brass bushing and when I cleaned out the pressed in bushing, I remember it looking uniformly grey. It may have been gunmetal blue, I didn't really concentrate that close on the color. Curious as to why yours was only colored on 1 side. Maybe there is a teflon insert or coating that has worn off. I only have 22k on the 15 ES. I know you have more mileage on yours. Interesting.
The blue is from heat treating to harden it so other components wear before it does. Ignore it, it's normal.
Toter and Bounce loved this
Good to know. With over 80k miles on the last and over 50k miles on this one, this is the first any hint of blue has shown. Still works as it’s supposed to. :)
x 12530
x 9433
When I went through all my clutch diagnostics a while back, I noticed the same thing. We pulled mine out and had a litany of cleaners on the bench that were used on all those parts. It was that grey/blue that you are talking about. It sure was a pain putting it back in the rubber boot.
nvrclvr4umname
FJRModel: 2015ES
x 19
x 12
Post by nvrclvr4umname »
bill lumberg wrote: Sat Sep 26, 2020 6:48 pm I am OCD, and I pull pegs and levers several times a year and clean and lube them................
Me too Bill. I won't speak to the pegs, but as for the levers, caliper grease is the best lube I've found to date, for the levers.
Bounce loved this
Bounce
FJRModel: 2003
x 7976
x 3776
Post by Bounce »
It's too easy not to do it when doing an oil change (or every other one).
tominca
FJRModel: 2005 ABS
x 121
x 480
Post by tominca »
Do the rest of you also have to clean the switch in the clutch housing. Mine gets fouled and the bike no longer starts with just the clutch pulled in, requiring a shift to neutral. I'm overdue to clean out the clutch bearing, but I always have to use contact cleaner on the switch.
It's a good day to ride
x 13186
x 6371
tominca wrote: Tue Sep 29, 2020 9:30 am Do the rest of you also have to clean the switch in the clutch housing. Mine gets fouled and the bike no longer starts with just the clutch pulled in, requiring a shift to neutral. I'm overdue to clean out the clutch bearing, but I always have to use contact cleaner on the switch.
No. Never. That sucks!
No. Never. That sux!
Really- I have NEVER cleaned any handlebar switch.
x 12959
If it's a Gen3 the clutch and brake lever switches require attention.
I use a silicone grease on the clutch/brake pivots, it won't wash out very easily. Caliper grease qualifies.
tominca
FJRModel: 2005 ABS
x 121
x 480
Post by tominca »
HotRodZilla wrote: Tue Sep 29, 2020 3:25 pm
Well, damn! That sucks. Why me?
