Cowling clips
Stop in & tell us who you are, where you are from, etc.
FFFDiesel
FJRModel: 2013 FJR
x 15
x 20
Cowling clips
Post by FFFDiesel »
Just reading the manual and apparently on my 2013 there are supposed to be clips that lock in the adjustable cowling vents in the fairing. Are they optional or should I worry about the insert popping out at highway speeds?
x 13145
x 6357
Re: Cowling clips
Do the Cowling Vents feel loose? The GenIII bikes are a little different, but the GenIIs have Dzus fasteners up top and the cowling hinges on the clips below. They come from the factory, correctly clipped in.
Unless something came apart or broke, or again, your cowlings feel loose or flap around, you shouldn't have to buy extra clips.
FFFDiesel
FJRModel: 2013 FJR
x 15
x 20
Re: Cowling clips
Post by FFFDiesel »
They don’t feel loose, but acccording to the manual there should be two locking clips at the bottom which are not there.
x 4139
x 4636
Re: Cowling clips
Are you sure? Have you looked at the empty hole where the fasteners should be?
x 3438
x 12720
Re: Cowling clips
There is a Dzus fastener with a thumb tab on each side at the bottom rear, turn 90 degrees to remove, 90 degrees to install... a bit finicky but they should be secure... if not, they can fall out.
When removed the panels can be slid forward on their slots to remove, reposition on the other set of slots, slide to the rear to secure, then install Dzus. I can't tell you they'll fall out, likely not but best get the fastener.... piece of tape will keep them from sliding I suppose, until you get the fastener.
FFFDiesel
FJRModel: 2013 FJR
x 15
x 20
Re: Cowling clips
Post by FFFDiesel »
Thx, guess I’ll head to the dealer tomorrow, couple of clips will be way cheaper than replacing that panel.
x 3438
x 12720
Re: Cowling clips
The fasteners can be finicky to get back in and into the lock position... PO may not have got them "locked" and they fell out.
Madmudder
FJRModel: 2014 FJR1300es Metallic Black
2023 FJR1300es Cobalt Blue
2022 Honda Goldwing tour DCT Blue
x 1856
x 381
Re: Cowling clips
Post by Madmudder »
Very few people have ever even tried them in the raised possition & for those who have found little or no difference.
2014 FJR1300es
x 3438
x 12720
Re: Cowling clips
They will keep a bit more water off your knees if raining, and a wee bit more cold breeze if it's freezing out. That's about it.
FFFDiesel
FJRModel: 2013 FJR
x 15
x 20
Re: Cowling clips
Post by FFFDiesel »
Madmudder wrote: Mon Jul 27, 2020 9:00 am Very few people have ever even tried them in the raised possition & for those who have found little or no difference.
I can see how it would be of no benefit, don’t really see myself pulling over to the side of the road to adjust them one way or another. Appreciate the info!
x 3438
x 12720
Re: Cowling clips
Naw, you adjust for the season/weather..... while you're still at home, I wouldn't do it on the road and haven't.
Re: Cowling clips
For two years, I adjusted them out for winter and in for summer. After a kerfluffle in another sandbox, I rode for a week with one out and one in. Couldn't tell a difference ... but that was in summer.
x 6048
x 10162
Re: Cowling clips
Uncle Hud wrote: Wed Jul 29, 2020 9:30 am For two years, I adjusted them out for winter and in for summer. After a kerfluffle in another sandbox, I rode for a week with one out and one in. Couldn't tell a difference ... but that was in summer.
I got mine back from a dealership with one in and one out. Doesn't inspire confidence in their work does it. :lol:
I notice no differene if you are in or out while riding.
As to the original poster. Not sure I am understanding. On my 13 they slide into two slots (maybe there are clips there). Then in the back there is a small plastic screw type thing you turn a half turn that locks them in place. They are very secure if you get them in right.
When I dropped my bike the first time it skinned one up pretty bad. I replaced it. I think that is the last time I have ever moved them.
If I remember right just slide the panel in the slots and make sure "14" is secure and you are good!
wheatonFJR and Madmudder loved this
Re: Cowling clips
:threadjack:
I rode a BMW K1600 around hot, sunny California which had 'slipstream deflectors', sort of a variation of the FJR air deflectors. They were a couple of silly little plastic pieces that rotate outward. I ignored the ridiculous things for most of the trip.
Then one day when it was ~105° I gave in and deployed them. Holy mother of dog! The wind ripped up the inside of my thighs, hit my crotch and went up inside my coat and blew up my coat like a balloon, exited at the neck and blew into the bottom of my helmet and tried to lift my helmet off my head. I have never seen an over-achiever like those slipstream deflectors. Apparently the Yamaha deflectors aren't quite as effective. I've never bothered to open them on my '15. Mebby I'll give 'em a try today so I can say I did something to my FJR.
Madmudder
x 1856
x 381
Re: Cowling clips
Post by Madmudder »
:lol: Don't expect anything like your BMW experience. Be sure to use a low scale Wind Anemometer to get your most accurate reading, you surely won't feel it.
2014 FJR1300es
x 3438
x 12720
Re: Cowling clips
You'll only notice the difference when it's colder and/or wet.... in warm, keep 'em in and you'll get a wee tad mostly unnoticeable airflow on your lower torso. You have to get down and look up perhaps to find those two Dzus fasteners at the rear end.
x 3998
x 6905
Re: Cowling clips
I'm an expert on riding in the cold living up here in igloomikfuktuk.
The panels, they do nothing.
FFFDiesel, HotRodZilla, and Madmudder loved this
x 13145
x 6357
Re: Cowling clips
I've said it before and I'll say it again: Those panels are the biggest set of bullshit gimmick do-nothing engineering some clown at Yamaha came up with to kiss his boss's ass. They serve no purpose than to add one more BS part that has the potential to break.
The dummy that came up with that needs a kick in the apple sack.
FFFDiesel, bungie4, D-Eagle and 1 others loved this
x 3771
x 5929
Re: Cowling clips
Hehheheh... “apple sack”
