Heli bar bridge. Removing Heli bar banjo. Bleed the system?
BruinFJRguy
FJRModel: 2015 FJR 1300 A
x 232
x 74
Post by BruinFJRguy »
Putting this under "farkles" (along with the kickstand question) because it isn't really "technical" info, just particulars to the given farkles.
I'm thinking about going without the installed Helibar bridge. Of course, I could leave the banjo, but it should go with the bar risers. Do I need to bleed/drain the system to do this? Will I get air in the lines if I just disconnect and reconnect?
Thanks for any help in advance!
Side note: I might have a very clean looking Heli bar bridge for sale shortly. I'll post it up if I decide to part with it.
x 2496
x 2022
Re: Heli bar bridge. Removing Heli bar banjo. Bleed the system?
You're better off to bleed the front brake circuit when opening the system up. If you want to try it, at a minimum, tie the brake lever back overnight and see if that gets a firm lever.
BruinFJRguy
x 232
x 74
Thanks, G. Bleeding is not a huge deal I guess. I actually moved the bars to the more foreward position in the bridge and it seems a little more twisty-amenable. We'll see.
x 3430
x 12679
I'd tend to keep the HeliBridge as most want risers anyway.... I moved mine to the full forward position as well and found that the best, new owner of my FJR likes it as well.
BruinFJRguy
x 232
x 74
Welp. After a trial run on 330 last night, I did like the forward position a lot better. Funny, I really meant to put risers/bridge on my last FJR. I just don't want to sacrifice handling.
Need another good trial ride today. Twisty riding in itself isn't exactly "confidence inspiring." :)
