:..Aux Plug not working..:
- hANNAbONE
- FJRModel: 2014 FJR 1300A
- x 27
- x 26
Glovebox plug on my 2014"A" isn't working. [GRRRRRRRRRRRRRRRRRr..!!]
I've checked and changed the fuse 3A
Still no go.
The group have any ideas??
TIA
Still no go.
TIA
hANNAbONE
...where hiways 421 & 50 kiss...
Versailles, Indiana
2014 FJR "A" Red-Head
Versailles, Indiana
- x 929
- x 2697
Re: :..Aux Plug not working..:
You got the right fuse, I assume?
Note: Only powered with ignition on.
Other than that, I can't help.
- hANNAbONE
- x 27
- x 26
yeah - tried all that, bike on etc.
Thx for the reply
I do have a YES thru late September, prolly hafta take it in.
Thx for the reply
hANNAbONE
Versailles, Indiana
Versailles, Indiana
- x 2212
- x 2997
Have you tested with a volt meter, or just like a USB plug-in device? I had a USB plug-in that was bad, socket was actually working.
Even though the schematic isn't clear about it, there is a coupler for the Aux Power plug behind the fairing. There are three couplers in the same spot, the Left Turn Signal, the Aux Power Coupler and the Accessory Box Solenoid coupler. These couplers are shown in section 2 of the FSM Cable Routing. Item 14 below:
Img coming soon. Dunno why normally good Smugmug is slow today.
The power for coupler 14 comes directly from the Aux Power fuse.
- x 2363
- x 14535
Edit - what Alan (ionbeam) said...
Next steps would be to pull the side panel and check to ensure that the plug on the back side of the outlet didn't come off or loose. From there, trace the wire back through the harness, checking connectors, etc.
Any other work done on the bike lately?
Tech day in the spring here in Michigan (most likely)- bring it, we'll keep Barry away from it and sort it out...
- x 3444
- x 12738
That wire will handle 5A, so you can put a 5A fuse in it if you want... use voltmeter.... check any USB or device you have plugged into it. Should be no need to go fishing for connectors.....
- x 2539
- x 2035
Confirm the socket is hooked up and a PO hasn’t repurposed it...
- hANNAbONE
- x 27
- x 26
I've tried three different adapters plugged in, with the ignition switch "on"
haven't tried the volt meter, that's a good idea.
hANNAbONE
Versailles, Indiana
Versailles, Indiana
- hANNAbONE
- x 27
- x 26
Yes, good to know and thanks for that schematic.ionbeam wrote: ↑Tue Jan 14, 2020 12:55 pm Even though the schematic isn't clear about it, there is a coupler for the Aux Power plug behind the fairing. There are three couplers in the same spot, the Left Turn Signal, the Aux Power Coupler and the Accessory Box Solenoid coupler. These couplers are shown in section 2 of the FSM Cable Routing. Item 14 below:
I'll get under the front end and see if things are still buttoned up tight.
Great idea - many thanks.!
hANNAbONE
Versailles, Indiana
Versailles, Indiana
- hANNAbONE
- x 27
- x 26
PO didn't mention anything about anything repurposed, albeit that could be the culprit.extrememarine wrote: ↑Tue Jan 14, 2020 12:58 pm Edit - what Alan (ionbeam) said...
I'll chase that down too.
I might just wait for the TechDay to figure it out too...great idea.!
Thanks for the reply
hANNAbONE
Versailles, Indiana
Versailles, Indiana
- hANNAbONE
- x 27
- x 26
I'escapefjrtist wrote: ↑Tue Jan 14, 2020 4:38 pm Confirm the socket is hooked up and a PO hasn’t repurposed it...
I
I'll climb under there and see what gives...Thanks for the reply
hANNAbONE
Versailles, Indiana
Versailles, Indiana
- hANNAbONE
- x 27
- x 26
really -- 5A -- welp, with that I might get back into the fuse dept and spice up that connection.
Thanks for your reply.
hANNAbONE
Versailles, Indiana
Versailles, Indiana
- Uncle Hud
- x 7246
Recently swapped mine out for two-port USB. Not an easy task, but ionbeam is correct: there is a diconnect coupling up high behind the pairing, and mine was thickly covered in road grime. A cleaning might be in order, after you check it for 12vdc with the ignition switch on.
- Bounce
- x 7873
- x 3735
I would never try to "out think" the engineers that spec's the fuse for that circuit. DO NOT OVERLOAD IT by swapping in a higher amp fuse. Why not just stuff a penny in there instead? Because it's unwise.
- x 12319
- x 9266
Duh, Pennies don't fit. Dimes are much closer. That is what I use.
Bounce loved this
- x 47458
- x 20139
This forum is awesome. THANKS!
- x 3444
- x 12738
Suggested reading.... wire gauges and amperages. It ain't a penny.Bounce wrote: ↑Wed Jan 15, 2020 11:31 amI would never try to "out think" the engineers that spec's the fuse for that circuit. DO NOT OVERLOAD IT by swapping in a higher amp fuse. Why not just stuff a penny in there instead? Because it's unwise.
