Need to order rear wheel.
- Prestone
- x 182
- x 137
Need new rear wheel and need help figuring out what can't be transferd over from the old wheel. I assume all the bearings, but what else. Thanks in advance.
- Auburn
- FJRModel: other ride
- x 2398
- x 1468
- Prestone
- x 182
- x 137
- x 3523
- x 12948
Re: Need to order rear wheel.
13 & up will fit/same. You will damage the bearings getting them out. Spacer, cush drive, abs sensor ring, brake rotor, all transfer over. You can use an '08-'12 wheel also, but silver not black.
IF I may ask, is the existing wheel damaged beyond repair?
- Prestone
- x 182
- x 137
I think it can be repaired but finding a place is the key close is the key. If have to spend a ton on shipping and a the repair it may not be worth it. Jwilly says there is a place in Atlanta. I'm going to call some local places on Monday.
- FJRModel: 2015 FJR1300ES
- x 8
I had a damaged rear wheel on my 15 and ended up just ordering from Partzilla. Good luck
- x 4053
- x 6947
Q: How do you damage the back wheel but not the front?
- x 48404
- x 20490
Wheelies through a "trials course", duh!
Madmudder loved this
- x 4053
- x 6947
I really should've known.
- NTXFJR
- FJRModel: 2016 FJR1300A
- x 2900
- x 1527
Should've known.....
That Wheatie would jump in with his .02...
bungie4 loved this
- jwilly
- Site Admin
- x 2249
- x 2148
This the place that repaired my front rim right before I left for YFO/EOM.
https://www.metrowheels.net/Services-Re ... nditioning
- x 3523
- x 12948
I usually keep my eyes peeled for FJR parts from various sources..... if I find one you'll be the first to know.
