Oil filter tightness..
CollingsBob
FJRModel: 2024 BMW R1300 GS
x 6412
x 2794
Post by CollingsBob »
Whats the preferred meaurement for correct oil filter tightness?
The 12 lb-ft spec’d in the owners manual..or the 3/4 turn mentioned in various sandboxes?
John d
FJRModel: 2008A
x 929
x 647
Re: Oil filter tightness..
Post by John d »
I just turn it by hand until I can't turn it anymore. Never a problem.
extrememarine, gixxerjasen, bungie4 and 3 others loved this
x 4466
x 12617
The guy at the Yamaha factory believes the proper setting is 150 ft. lbs.
I'm with John d, just hand tight or a tiny bit more with a wrench if you are paranoid.
HotRodZilla, gixxerjasen, wheatonFJR and 1 others loved this
Hand tight isn't what it used to be. After a major surgery on the left hand a few years ago plus a little bit of arthritis in both, I am a bit more secure with Festus's method - hand tight plus a bit.
x 48417
x 20490
Yeah, just changed the oil and filter on a used bike I purchased, and 150ft lbs probably wasn't too far off. I'm actually surprised that the filter wasn't a gnarled mess when it was installed from the massive torque.
Festus loved this
x 14699
Hand tight as mentioned. I've also read something along these lines "tighten until gasket makes contact, then tighten a 1/4 turn."
I have followed that on my FJR's and Harley - spin it on until it stops, then a 1/4 turn further.
When I was younger, my dad made me stop using an oil filter wrench on the truck / car to put on the oil filter because we (me) were having to use a punch or screw drive through the filter to get it off... So "hand tight" became "spin it on until it stops, then a 1/4 turn further".
gitbox, HotRodZilla, Cav47 and 2 others loved this
x 12953
It's usually stated on the filter... first, oil the gasket, then install I go 1/2 turn after gasket contacts base. Don't use a Purolator or Bosch, they won't seal properly unless you have the Norm Kern modded filter adapter or shave 0.060" off the nut face on yours.
CollingsBob
x 6412
x 2794
So, nobody uses a torque wrench...interesting
x 12953
The torque wrench thang was on Honda and Suzuki OEM filters that had a big fat O-ring as a gasket. Even torquing that was a bit silly.......
CollingsBob
x 6412
x 2794
In my opinion it looks like another instance where a user group has found a better method than the factory..perhaps in this case the factory was/is being overly cautious, defaulting to a measurable value.
x 3042
x 3261
I use the torque wrench on everything, including the oil plug (22 lbs based on people having problems stripping with the factory specs). I use 12 lbs on the oil filter. Never a problem. Of course on my SUV's I use the hand tight method (usually I think 3/4 turn after contact). Never a problem there either. Most likely you're not screwing it up either way. On the bike I'll take the extra time and torque wrench because it's so easy to get at compared to the SUV's.
I did get made fun of at tech day for using a torque wrench but after years and years of stripping everything I touched (to make sure they were tight enough) I gave up and bought a torque wrench. I'll take the ribbing over a helicoil.
x 6276
x 10350
I use the hand tight method, and always need the tool to get it back off when the time comes. Hand tight does not equal hand loosen.
gitbox, HotRodZilla, Cav47 and 3 others loved this
x 48417
x 20490
gixxerjasen wrote: Tue Jul 30, 2019 10:40 am I use the hand tight method, and always need the tool to get it back off when the time comes. Hand tight does not equal hand loosen.
You call NTXFJR over to your place to get it off? What?????
x 1647
I rotate until my right wrists clicks. :shock:
HotRodZilla, D-Eagle, Cav47 and 3 others loved this
dcarver wrote: Tue Jul 30, 2019 12:36 pm I rotate until my right wrists clicks. :shock:
So, do you call that a dork-wrench?
Toter, Pterodactyl, HotRodZilla and 1 others loved this
Hand tight plus a bit. The only thing you're doing is compressing the gasket against the block to seal. No worries.
Plus, if it isn't tight enough...you'll know.
x 4054
x 6947
Make sure the old gasket comes off with the old filter. Wipe the mating surface. Oil the new gasket. Good'n hand tight.
bungie4 wrote: Tue Jul 30, 2019 2:47 pm Make sure the old gasket comes off with the old filter. Wipe the mating surface. Oil the new gasket. Good'n hand tight.
^^^^ This has never failed me. At a NERDS fall ride in Acadia I had a drain plug crush washer weep but never had a filter gasket leak, car or bike.
x 4054
x 6947
ionbeam wrote: Tue Jul 30, 2019 3:19 pm
The real brain stem rotator is if you should drain your oil hot or cold. Personally, I always do it cold, because all the icky bits are completely drained into the pan and are in suspension. Starting it and redistributing the oil, along with the icky bits, back through your engine seems wrong to me. (Once in a while I'll drain hot just in case LOL!)
If you have bigger bits that have to be 'stirred' up before draining, man, you've got bigger problems.
Re: RE: Re: Oil filter tightness..
Do it cold because bathing your hands in hot oil sucks. There are still bits of stuff in the engine that will never come out with an oil change.
Also, trick I learned from a guy that's been changing oil since it started being refined: use the old filter to lube the new filter's gasket by touching the gaskets together. It gets really obvious if the old one isn't there. For some reason the human mind can see something that's missing better than something that isn't supposed to be there.
