MCL/Blackpath bar risers
A small downside to fitting a RDL seat is a slightly greater lean to the bars. I’m considering bar risers...Do either the MCL or Blackpath risers necessitate extensions to the clutch or brake lines?
- Bikenagain
- FJRModel: 2006
- x 13
- x 5
Re: MCL/Blackpath bar risers
MCL if you can find some don't need any extensions, just install and ride.
" Where ever you are - there you be"
- x 484
- x 1319
I used Genmar 1" for yrs & yrs, no mod of anything else required. I'm now using the old HeliBars replacement pullback top plate and the Genmar 1"- no modification of any hoses required other than re-routing on the right side. By "re-routing" no disconnection of any hoses or wiring, just push them to the inside towards the steering stem.
- x 921
- x 2676
If I had known you were considering risers, you could have tried my Genmar risers out with your seat on my bike when I was there. No extensions needed if a 1" rise is enough for you.
