how do you access horns on 2003 fjr1300?
Rajuur
FJRModel: 2003 fjr1300a
Post by Rajuur »
how do you access horns on 2003 fjr1300a?
do you have to remove any plastic?
x 14700
Re: how do you access horns on 2003 fjr1300?
From the front of the bike, they are back in front of the radiator - you should be able to see them if you look under the headlights and above the front fender / wheel. You should be able to remove / replace them without removing the side panels.
Rajuur wrote: Mon Jun 17, 2019 3:57 pm how do you access horns on 2003 fjr1300a?
Rajuur
Post by Rajuur »
Extrememarine: Thanks. Will give it a try.
Bounce
FJRModel: 2003
x 7976
x 3776
Post by Bounce »
