Final Drive Oil Leak
RacinRay
x 166
x 837
Post by RacinRay »
I was walking by my '16ES (35K miles) last week and I noticed a few drops oil on the floor just ahead of the pumpkin. Upon closer inspection I found oil residue and grime all over the final drive, rim and halfway up the swing arm. I cleaned up the oil on the floor and it hasn't leaked any more.
I can't see where the oil is leaking from but it appears to be a fair amount. I haven't changed the gear oil recently so I don't think it was an over fill issue. There are no other oil spots on the floor. Any thoughts or suggestions on how to proceed?
x 47298
x 20085
Re: Final Drive Oil Leak
RacinRay wrote: Sun Apr 28, 2019 1:43 pm I was walking by my '16ES (35K miles) last week and I noticed a few drops oil on the floor just ahead of the pumpkin. Upon closer inspection I found oil residue and grime all over the final drive, rim and halfway up the swing arm. I cleaned up the oil on the floor and it hasn't leaked any more.
Was Marty in your garage? He's been known to ummm...play tricks. We're you just at Busts tech day?
If neither of those things occurred, I got nuttin.
RacinRay
x 166
x 837
Re: RE: Re: Final Drive Oil Leak
Post by RacinRay »
None of the above.
The oil level didn't look low when I just took out the top plug.
kieefjr
x 154
x 150
Post by kieefjr »
There is a small hole on the flat surface ahead of the pumpkin, that’s most likely where it came from.
The seal there is an easy fix but I would just watch it and if it keeps dripping that seal may need replacing.
x 3432
x 12695
Shouldn't be a seal failure at that low mileage..... too much grease on the rear wheel splines at a tire change will fling off...... can't 'splain anything else, overfill would have oil spray out the upper vent...... just keep an eye on it. You can pull the pumpkin next tar change and see what's happening maybe?
RacinRay
x 166
x 837
Post by RacinRay »
kieefjr wrote:There is a small hole on the flat surface ahead of the pumpkin, that’s most likely where it came from.
That makes sense given where I found the oil (ahead of the pumpkin).
Thanks. I'll keep an eye on it.
RacinRay
x 166
x 837
Post by RacinRay »
Well, it's definitely leaking from the weep hole in front of the pumpkin.
I have a 5 day ride starting on the 16th. I don't know if I can get it fixed by then. I wonder if I can swap the pumpkin from my '06?
RacinRay
x 166
x 837
Post by RacinRay »
The oil seal is on backorder. #$@&!
blind squirrel
FJRModel: 2014
x 1539
x 2582
Post by blind squirrel »
FJR pumpkin failure is IMMENENT! Death! Destruction!!
x 47298
x 20085
blind squirrel wrote: Wed May 08, 2019 5:27 pm FJR pumpkin failure is IMMENENT! Death! Destruction!!
Racin Ray...take photos...yours may be the first I've heard about????
RacinRay
x 166
x 837
Post by RacinRay »
Does anyone know if a 2006 pumpkin is a direct swap for the 2016?
RacinRay
x 166
x 837
Post by RacinRay »
I was just thinking that this is the first time in 13 years of owning FJRs that I've had a part fail. A great record but an unfortunate time for a failure.
x 3432
x 12695
Same pumpkin, go for it.
(It's not, but physically same, will bolt on).
Existing seal should not catastrophically fail.
