GEN II LED Flasher Relay
Auburn
FJRModel: other ride
x 2255
x 1421
Post by Auburn »
After years of putting up with the fast flash rate from switching to LED turn signals, I finally have all the body work off for this winters maintenance.
First shot is the front of the bike with the nose off.
Looking from the right side there are two relays straight above the fender, the small one on top is the flasher relay. (right above my finger white connector) I have the aftermarket one already installed.
I installed a Custom LED https://www.amazon.com/Custom-LED-Elect ... 19&sr=8-14 which was plug and play. Works great. I think they are cheaper on eBay, but this was easy to find for an example.
the stock flasher is a FE246BH and can be bought anywhere
NTXFJR loved this
get out and ride!
IBA #708
2024 Goldwing
x 1614
Re: GEN II LED Flasher Relay
Winter maintenance? Doode! It's April! :lol:
Auburn loved this
MindWebs
FJRModel: 2012 FJR, Current.
x 23
x 30
Post by MindWebs »
Excellent write up!!
Very helpful!
Electronic flasher relay on ebay: $22.96
https://www.ebay.com/itm/Durability-Ind ... Swe-FU7a-T
But just to help a bit further what are the bulb numbers for the turn signals?
I haven't hat to pull any yet.....
Some people are lucky i guess?
2012 FJR, front and rear crash guards, highway pegs, throttle lock, driver backrest, 1" bar risers, pirelli angels normal spec.
I'm not sliding, It's rear wheel steering!
