Thank You, DesignFlaw06!
Some of you may know that my topbox has an “organizer” in it. I’ve enclosed the term in quotation marks because it’s a really homemade thing, created out of cut-up SlimJim boxes and duct tape. It holds wallet, house keys, pens, aspirin and ibuprofen, air pressure gauge, a spare FJR key, a case with balaclava, blah, blah, blah, and other stuff that should be kept handy.
Note duct tape binding SlimJim boxes together and holding the entire contraption to the topbox wall. The duct taped boxes worked well for a couple of years, then the cardboard began falling apart. So, I made a new one, with a sturdier box for wallet and keys. The 'improved' one is pictured. As you can see, it still in pretty good shape, but I realized it probably wouldn't make it through the summer.
... and then I got an idea! DesignFlaw06 has a 3-D printer. Could he make one for me? Of course he could!
After a few email exchanges, we got our concept ironed out and my questions answered. The material is the same as used in FJRiders license plate frames: sturdy, durable, and resistant to most anything your motorbike will experience.
DesignFlaw06 offered a few suggestions for an improved version. They were all great, so he began spinning his tiny plastic filaments like Spiderman building a shield.
Here’s the final product. It has several slots that make it possible to adjust the size of each compartment. I’ve gotten it settled in now, and experimented with how the stuff will fit into each compartment.
The green stuff has been there since I got the box from Petey. It's contoured padding cut carefully and glued to the topbox bottom, because I CANNOT STAND RATTLES.
And last, here’s what everything looks like as I arrive at work each morning:
I’m VERY satisfied with the product, and with the suggestions Tim offered.
If you have something you’ve been thinking about doing to your bike, drop him a PM and see what he can do for you. It helps that he’s a motorbike rider and understands how the product will be used. It also helps that he knows how to work his special magic with plastics.
Thank you again, DesignFlaw06!
jwilly, Redfish, HotRodZilla and 7 others loved this
x 1425
x 3465
Re: Thank You, DesignFlaw06!
Tim Dog!!
DesignFlaw06 loved this
x 15300
x 14204
Wow!!! Now that is cool.
x 3434
x 12709
But the duct tape looked so nice!
CraigRegs
FJRModel: 15ES
x 4163
x 2778
Post by CraigRegs »
Nice work, Tim! I don't have a top box, but the wheels are turning about what one could do in a side case...
DesignFlaw06 and Uncle Hud loved this
Craig
...the Pursuit of Happiness
x 6035
x 10161
Them 3-D printers are cool. Could I order a Gatling Gun?
Seriously that looks awesome.
I have been thinking about doing something like that out of wood.
x 6239
x 3971
danh600 wrote: Thu Apr 04, 2019 2:26 pm Them 3-D printers are cool. Could I order a Gatling Gun?
I'm sure he could, Dan.
But there's liability involved.
That's great, Hud, looks made to order!
blind squirrel
FJRModel: 2014
x 1539
x 2587
Post by blind squirrel »
How do you affix it to the side of the box?
natehawk750
x 2166
x 2443
Post by natehawk750 »
I liked the cardboard version better.
Nah nice job DesignFlaw!
Oh and cute man purse UncleHud!
Redfish and Uncle Hud loved this
#69272
x 243
x 1900
Glad I could help. I know it's just a box, but it is a satisfying feeling when you design something, print it, and it just works.
Actually this was fun to work on. In an effort to make things harder on myself, I used it as an opportunity to get better at understanding the modeling software. Something I wish I would have done before making all of those license plate frames. It would have saved me a ton of time there. The box did have the challenge of being longer than the dimensions of my printer, which is why it is printed in two pieces.
It's such a fun tool to have.
Hppants and CraigRegs loved this
x 2360
x 14520
pretty awesome!!
blind squirrel wrote: Fri Apr 05, 2019 6:57 am How do you affix it to the side of the box?
Good question. It wedges in very tightly -- actually a bit tighter than expected because the topbox walls taper inward slightly as they reach the bottom. So ... it affixed itself inside the topbox with a few soft suggestions from a rubber mallet, and IT DOESN'T RATTLE.
I've been using it for about two weeks now, including a six-hour run into rural SC yesterday. No complaints about anything.
Perhaps someone should consider changing their screen name to "DesignFlawless06".
CraigRegs wrote: Thu Apr 04, 2019 1:50 pm Nice work, Tim! I don't have a top box, but the wheels are turning about what one could do in a side case...
Making something to organize the hardcase contents would be a killer idea.
x 243
x 1900
Uncle Hud wrote: Fri Apr 05, 2019 11:05 am
Not impossible. A bigger design effort than just a box, but I'm sure something could be done.
x 6035
x 10161
Do you use basically the same plastic material to make most projects?
x 243
x 1900
danh600 wrote: Fri Apr 05, 2019 1:03 pm Do you use basically the same plastic material to make most projects?
No. It depends on the application.
PLA (Most Common)
Pros: Easy to print, no bad odor, no shrinkage, good overhang and bridging properties
Cons: Brittle, susceptible to warping, not suitable for prolonged outdoor use
ABS
Pros: Strong material, suitable for outdoor use, easier to finish parts, less prone to warping
Cons: Harmful fumes and odor, shrinkage, difficult bed adhesion
PETG
Pros: Has most of the printing properties of PLA with the similar strength of ABS, durable material, excellent bed adhesion, good layer adhesion
Cons: Stringy, susceptible to humidity while storing, glossy finish
Those are the basics. I use PLA for my basic stuff such as toys or trinkets. Functional stuff usually gets the PETG filament. There are plenty more filament types. Nylon is one of the more durable and stronger materials you can print. There are some carbon fiber filaments out there also. Recently I've been experimenting with TPU. That is a flexible filament that you can squeeze like a toy if you want.
Hppants and danh600 loved this
PS: My organizer has no perceptible odor.
BikerGeek
x 5378
x 4711
Post by BikerGeek »
Intech wrote: Thu Apr 04, 2019 12:24 pm Tim Dog!!
FOR PRESIDENT!!
DesignFlaw06 and wheatonFJR loved this
BikerGeek
x 5378
x 4711
Post by BikerGeek »
DesignFlaw06 wrote: Fri Apr 05, 2019 1:55 pm ... no bad odor, no shrinkage, good overhang ...
Wait.
What're we walking aboot again?
Redfish, HotRodZilla, wheatonFJR and 2 others loved this
x 13145
x 6352
Cool.
DF06, Which of those. Materials did you use for the license plate frames? No reason just curious.
