Front wheel abs sensor
The abs sensor mount for the rear wheel is held in position by engaging a tab on the swing arm..what stops the abs sensor mount on the front wheel from rotating?
- x 15258
- x 14137
Re: Front wheel abs sensor
The front wheel ABS sensor has a "tit" on it the is supposed to fit within a similar complementary indention on the left front lower fork.
Being the first to answer a technical question correctly feels.... empowering!!
- Intech
- x 1420
- x 3456
Actually the "tit" is on the fork and engages a slot on the ABS housing. Don't get rambunctious!
gixxerjasen, El Toro Joe, CollingsBob and 2 others loved this
- x 15258
- x 14137
Dammit - so close, and yet so far...
Intech and CollingsBob loved this
The important take-away is that there is a tab and a slot, it doesn't really matter who is on top which is on the right or left.
Redfish loved this
