Centerstand & relay arm maintenance ..
CollingsBob
FJRModel: 2024 BMW R1300 GS
x 6412
x 2794
Post by CollingsBob »
As soon as it’s warm enough in the garage to work on the bike I’m going to tackle the centerstand and relay arm lube job..
Apart from the centerstand bolt that will get cut off to remove it, are there any other bolts,nuts, parts that I should order?
Full House
FJRModel: 2010
x 2713
x 277
Re: Centerstand & relay arm maintenance ..
Post by Full House »
Bob, just finished mine, the bolts are 10mm x 1.25 x 30mm long. I couldn't get hex head, got socket head instead. The additional thickness of the head made install more difficult. If you are buying ahead of the teardown, order the hex head bolts. Are you doing the grease fitting install? I asked for and received Russ's pics, etc however I wont be doing it again for sometime.
CollingsBob
x 6412
x 2794
I’m pretty sure that I’ll do the grease fitting install later this summer, Russ is out of commission for a bit and my bike needs its 25,000km maintenance pretty soon. I’m off to the Yamaha dealer to get the bolts and Honda brake pins at the same time..
huron52
x 101
x 308
Post by huron52 »
Got to ask ..... why are you doing this?
CollingsBob
x 6412
x 2794
huron52 wrote: Sat Mar 16, 2019 4:28 pm Got to ask ..... why are you doing this?
Why am I doing the scheduled maintenance?
fjrob
FJRModel: 03
x 385
x 837
Post by fjrob »
I'm with Tom. Why? I spray the joint with rust check now and then. No need to remove it.
#1 frost back!!!
CollingsBob
x 6412
x 2794
I suppose there are a wide range of opinions on this...
huron52
x 101
x 308
Post by huron52 »
fjrob wrote: Sat Mar 16, 2019 7:18 pm I'm with Tom.
Now that is funny right there!
Snowflake
FJRModel: 2014ES
x 6
x 92
Post by Snowflake »
This is what I found after letting my '05 go too long without proper relay arm maintenance. Ignore at your own risk.
This is what drove me to develop the zerk fitting install mod.
x 3431
x 12685
There are grease seals on them thar bearings..... spraying from the outside ain't gonna do it I'm afraid. At the least, you can remove the links and lower shock mount, pivot the suspension arm down to lube all but the front frame mount. Takes all of 30 minutes.
John d
FJRModel: 2008A
x 926
x 647
Post by John d »
Here is a link about the relay arm I have with zerks.
http://www.fjrforum.com/forum//index.ph ... e-service/
John d wrote: Mon Mar 25, 2019 2:14 pm Here is a link about the relay arm I have with zerks.
Which Russ has re-posted to this Forum today, see it here.
John d
FJRModel: 2008A
x 926
x 647
Post by John d »
ionbeam wrote: Mon Mar 25, 2019 2:18 pm
Missed that. So Snowflake is FJReady.
John d
FJRModel: 2008A
x 926
x 647
Post by John d »
My previous relay arm.
Snowflake
FJRModel: 2014ES
x 6
x 92
Post by Snowflake »
John d wrote: Mon Mar 25, 2019 2:24 pm
Yup. I used Snowflake when I joined the FJ-09 forum and one other (advrider?) Figure FJReady wouldn't have much significance there. When I joined this sandbox, around the same time I think, decided to stick with Snowflake. That's an old nickname with my skiing buddies, earned for having the reputation for getting lost on the slopes. I like getting lost on my bike too. Sorry for any confusion.
John d loved this
x 3431
x 12685
And some will remember this gem, the Best Tire Balancer EVAR! Love mine.
Auburn loved this
Snowflake
FJRModel: 2014ES
x 6
x 92
Post by Snowflake »
raYzerman wrote: Mon Mar 25, 2019 9:05 pm And some will remember this gem, the Best Tire Balancer EVAR! Love mine.
Glad that's working out for ya.
