front fork rebuild
- FJRModel: 07 FJR1300
- x 169
- x 172
front fork rebuild
My 07 FJR has been making funny noises for a long time, and now it's weeping fork oil. I also want to install racetech fork springs and, if possible, new sliders, so I am back to NEW or maybe a little better. I have purchased a fork seal replacement tool, and I have a compresser and an air gun. I do NOT have any way to remove the middle slider. I am reading all the info on the web about how to do all this and I have a garage to work in. If there is anyone on the forum who is local to me. Laurens, SC 29360. and needs to do this also, maybe we can work together and do both. Either one at a time, or at the same time. PM me if your interested, either at my place or yours. Phil
- x 6284
- x 10352
Re: front fork rebuild
We really don't need to bring my name into this.
The middle one will remove with the slide technique, if you do the technique right. I highly recommend getting help or taking it somewhere like Traxxion because doing it wrong could potentially be frustrating and expensive. FYI, most don't reinstall the middle one and even though I provided them to Traxxion they did not install them and I felt no perceptible difference in them.
- x 48438
- x 20503
Doncha love it when people use your forum handle as a verb...
HotRodZilla, CraigRegs, and gixxerjasen loved this
- x 12960
Using the usual slide hammer technique, the middle bushing will come out..... there is a potential, as the middle bushing hits the upper bushing, the lower bushing goes inside the middle thus expanding it and jamming it, causing the surrounding air to become blue and your swear jar fills up. BFH rubber hammer, pound it back, may have to repeat a few times. A trick if there is such a thing is not to pull in perfect alignment, make that lower offset the middle, BUT, the secret is to heat up the upper bushing area quite hot (do not melt the aluminum!!) until you can burn yourself, and slide away. The upper bushing crazily is an interference fit, thus in there under significant pressure. Heating the aluminum will expand the bore.
If you want some practice, I have a set of forks here that have had no cartridges or oil in them for a coupla years or more. I can't get them apart, maybe you can..... NOT. I have gixxerjasen'd one of them.... but I haven't given up yet.
My new opinion on spring kits, go with the Traxxion springs, they come with the spacers pre-cut, and the plastic bushings that keep the springs centered (you pay $50 extra to RaceTech for this). EZPZ.
- x 6284
- x 10352
Yep, advice I was given after the fact is to slide like you are trying to bend it. Give a pull on the inner tube so the bushings don't hit square. If you feel it slide inside the other one more than once, stop. Take it somewhere.
Interesting Ray, didn't know you gixxerjasen'd yours. And you did the full gixxerjasen unlike HRZ with Mountain's forks. Good show sir. Now we have a matching pair.
Just think though, if you'd done it first, raYzerman could be a verb.
blind squirrel and wheatonFJR loved this
- HotRodZilla
- FJRModel: 07 FJR-A
- x 13186
- x 6371
Shit, after helping do Josh's forks the biggest thing I learned was, I will NEVER do my own forks if I don't have to. I have access to an awesome Yamaha guy that will knock that out for me for a couple hundred. Totally worth the cost. You guys that do your own forks have my respect!gixxerjasen wrote: ↑Mon Nov 12, 2018 2:02 pm Yep, advice I was given after the fact is to slide like you are trying to bend it. Give a pull on the inner tube so the bushings don't hit square. If you feel it slide inside the other one more than once, stop. Take it somewhere.
Just think though, if you'd done it first, raYzerman could be a verb.![]()
- x 169
- x 172
Just curious, what do the "professionals" do that we can't do? Is there a tool?
- x 48438
- x 20503
Yes, gixxerjasen is in the house...so yes, there IS a tool.philharmonic wrote: ↑Tue Nov 13, 2018 12:16 pm Just curious, what do the "professionals" do that we can't do? Is there a tool?
Seriously though, if I was gonna have an issue with front forks on a 2007...I would probably call up the best shade tree mechanic (IMO)there is. I believe he has a 2007 and lives somewhere near Laurens, SC.
- x 6284
- x 10352
they'll likely do a similar task, they just have more experience in doing it. You can get your own experience, just know that sometimes experience is expensive. I can personally attest to this.
I do my dirt bikes and stuff now, but that inner bushing, I'd sent off to Traxxion or someone. Once that middle bushing is out of there, I don't think I'd be scared of it. That said, when it comes time to rebuild my FJR forks, they'll go to Traxxion, simply because the AK20's are in there, but I'd do the rest of them myself.
- x 169
- x 172
Alright, one more question before my name becomes a verb.
Is there a place that is good at doing this or that one of you has experience with, within driving distance of Greenville, SC. I can't imagine having to ship these both ways to someone.
- x 169
- x 172
I wrote the above post, thinking about what I will do if I gixxerjason up the forks and need someone to un-gixxerjason them not to do the whole job. LOL
- x 48438
- x 20503
Phil er harmonica: I have driven my forks up to...philharmonic wrote: ↑Tue Nov 13, 2018 1:15 pm Alright, one more question before my name becomes a verb.
Cogent Dynamics,
33 Meadow Brook Dr,
Fletcher, NC 28732, United States
Might be handy in case you harmonica-size your forks.
- Steel_Gin
- FJRModel: 2012 FJR1300A
- x 1428
- x 446
I am sharing this on the condition no one asks me how I know/learned this. Don't forget to remove the Snap Ring & seal, #10 & 35 on the diagram for my '12, before you start trying to remove the middle slider. It does a very good job keeping it in place.
philharmonic, HotRodZilla, and wheatonFJR loved this
- x 48438
- x 20503
Sounds like more than one Gen2 owner have had to fight with that middle bushing...gixxerjasen has been everywhere!
- x 6284
- x 10352
This shall be known as deanging your forks.
If you fully gixxerjasen (use the whole name plesase
Steel_Gin loved this
- x 169
- x 172
Now that would really toast my buns if I had to go up into the mountains with PARTS of my motorcycle instead of my whole motorcycle.wheatonFJR wrote: ↑Tue Nov 13, 2018 1:46 pmPhil er harmonica: I have driven my forks up to...philharmonic wrote: ↑Tue Nov 13, 2018 1:15 pm Alright, one more question before my name becomes a verb.
Cogent Dynamics,
33 Meadow Brook Dr,
- x 48438
- x 20503
Sometimes a little at a time is progress.philharmonic wrote: ↑Tue Nov 13, 2018 8:52 pmNow that would really toast my buns if I had to go up into the mountains with PARTS of my motorcycle instead of my whole motorcycle.wheatonFJR wrote: ↑Tue Nov 13, 2018 1:46 pmPhil er harmonica: I have driven my forks up to...philharmonic wrote: ↑Tue Nov 13, 2018 1:15 pm Alright, one more question before my name becomes a verb.
Cogent Dynamics,
33 Meadow Brook Dr,
- x 371
- x 2007
Shadetree?......SHADETREE?!?!?!?wheatonFJR wrote: ↑Tue Nov 13, 2018 12:48 pmYes, gixxerjasen is in the house...so yes, there IS a tool.philharmonic wrote: ↑Tue Nov 13, 2018 12:16 pm Just curious, what do the "professionals" do that we can't do? Is there a tool?
I have a nephew that's an arborist.
I don't need any fork work at the moment Phil, but we do need a trip to Wade's on either Turkey and Dressing day or Chicken and dressing day
https://www.eatatwades.com/daily-menu
And I am certainly willing to laugh at spectate if you think you might gixxerjasen or deang something up
edit: +1 on traxxion
and there is also https://www.bubbasbbqandbash.com/menus/
- x 48438
- x 20503
Whups...Looks like I stepped in it again!
What I thought it meant, I guess it doesn't...my apologies. I thought it was a person who could MacGyver anything out of a twisty piece of wire and a piece of rubberband. I have just learned it isn't...and have offended my friend. Sorry!
- x 169
- x 172
Wow, I could eat at BOTH of those restaurants, often, as long as someone doesn't rat me out to my Cardiologist.1911 wrote: ↑Thu Nov 15, 2018 7:11 amShadetree?......SHADETREE?!?!?!?wheatonFJR wrote: ↑Tue Nov 13, 2018 12:48 pmYes, gixxerjasen is in the house...so yes, there IS a tool.philharmonic wrote: ↑Tue Nov 13, 2018 12:16 pm Just curious, what do the "professionals" do that we can't do? Is there a tool?
As far as my forks go, I have MacGyvered my left fork seal with a homemade piece of milk carton, {I prefer Bordens since my son works there, LOL} and we will see what happens, I have not, as yet, ruined my brake shoes, so I have that to look forward to.
