Need a better horn on the FJR!
- x 6247
- x 10421
Some of you guys have replaced the horn on your FJR. Is this just a standard part you are buying at an Auto store?
I assume it's an easy replacement that even a bad mechanic like myself can do?
Also my wife wants to put one on her Indian Scout. I would think the same horn that is used as a replacement on an FJR would work just as well on almost any bike.
- HotRodZilla
- FJRModel: 07 FJR-A
- x 13186
- x 6371
Re: Need a better horn on the FJR!
PIAA Slimline Sports Horn. Buy the two pack set. They're around $50 on Amazon and eBay. 300hz and 400hz. They're easy to install, no relay needed, and they're LOUD.
Harald, LKLD, Uncle Hud and 2 others loved this
- x 4055
- x 6948
! You just reminded me I've got a pair of these in the shed that I never installed. Lets see, I bought them at the last house... so, I've had them for at least 2 years, likely double that.HotRodZilla wrote: ↑Tue Oct 09, 2018 9:02 am PIAA Slimline Sports Horn. Buy the two pack set. They're around $50 on Amazon and eBay. 300hz and 400hz. They're easy to install, no relay needed, and they're LOUD.
I guess I don't like rushing into things. Considering I haven't had the chance to ride my bike for two weeks now and the temps have gone to single digits.. could you remind me in the spring?
Bust loved this
- Geezer
- x 76
- x 622
Fiamm Freeway Blaster horns have been popular for use on the FJR as well as the Nautilus Compact air horn. I used a pair of the Freeway Blasters for a long time and eventually they lost their punch from grit getting inside, so I switched to the air horn. Either one works great. Take a look in the fjrforum and you will find a lot of discussion about horns and how people installed them.
- HotRodZilla
- x 13186
- x 6371
Ha! I have stuff here that I've had for easily two years that I haven't installed yet. Too busy doing other stuff. I'll tell you what, you remind me, and I'll remind you. That's a perfect plan!bungie4 wrote: ↑Tue Oct 09, 2018 9:14 am! You just reminded me I've got a pair of these in the shed that I never installed. Lets see, I bought them at the last house... so, I've had them for at least 2 years, likely double that.HotRodZilla wrote: ↑Tue Oct 09, 2018 9:02 am PIAA Slimline Sports Horn. Buy the two pack set. They're around $50 on Amazon and eBay. 300hz and 400hz. They're easy to install, no relay needed, and they're LOUD.
- x 48437
- x 20503
^^^^HotRodZilla wrote: ↑Tue Oct 09, 2018 9:02 am PIAA Slimline Sports Horn. Buy the two pack set. They're around $50 on Amazon and eBay. 300hz and 400hz. They're easy to install, no relay needed, and they're LOUD.
This is the correct answer.
2 points for Zilla.
Uncle Hud and Bust loved this
- x 6247
- x 10421
Looks like the PIAA is pretty much plug and play.
Just order them from Amazon. I will try a pair on the FJR. Then probably put them on all the bikes.
Well, except the Valkyrie. That bike came stock with a great horn.
Not exactly plug and play. The Gen2 came with 2 horns so the wiring is already there. Gen3 come with one horn, you'll have to add the crossover wiring.
- x 4055
- x 6948
So what your saying is I should just put them in my will...HotRodZilla wrote: ↑Tue Oct 09, 2018 10:05 amHa! I have stuff here that I've had for easily two years that I haven't installed yet. Too busy doing other stuff. I'll tell you what, you remind me, and I'll remind you. That's a perfect plan!bungie4 wrote: ↑Tue Oct 09, 2018 9:14 am! You just reminded me I've got a pair of these in the shed that I never installed. Lets see, I bought them at the last house... so, I've had them for at least 2 years, likely double that.HotRodZilla wrote: ↑Tue Oct 09, 2018 9:02 am PIAA Slimline Sports Horn. Buy the two pack set. They're around $50 on Amazon and eBay. 300hz and 400hz. They're easy to install, no relay needed, and they're LOUD.
Bust loved this
- blind squirrel
- FJRModel: 2014
- x 1593
- x 2633
I only see 400Hz and 500Hz. https://www.amazon.com/85114-400Hz-500H ... B004FXMGLYHotRodZilla wrote: ↑Tue Oct 09, 2018 9:02 am PIAA Slimline Sports Horn. Buy the two pack set. They're around $50 on Amazon and eBay. 300hz and 400hz. They're easy to install, no relay needed, and they're LOUD.
- x 6247
- x 10421
So basically a third wire that goes from the positive of one horn to the negative of the other horn?
- x 4055
- x 6948
Only if you want to have a horn that sounds like a fart. Positive to both. Negative of both to ground.danh600 wrote: ↑Tue Oct 09, 2018 3:12 pmSo basically a third wire that goes from the positive of one horn to the negative of the other horn?
gitbox, wheatonFJR, and danh600 loved this
- FJRModel: 2015 A
- x 49
- x 294
Re: RE: Re: Need a better horn on the FJR!
That would surely confuse other motorists.
Dumb Motorist: "Just let me merge blindly into this other lane..."
FJR dude: PBBBFFTTT...crunch...ahhh my leg!
Dumb Motorist: "Was that farting I heard?"
- x 12960
One used to be able to get PIAA's in 500 and 600...... is more of a European sound, while the 400-500 is more like a standard 'Merican car.
- Uncle Hud
- x 7246
The PIAAs aren't quite plug-and-play, but installation is pretty simple. Used a three-blade connector to add the crossover wire on mine -- two feet of 20 or 22 AWG is sufficient for the crossover. The three-blade solderless terminal connected the power wire to the original location and allowed the 'crossover' wire to get the same signal from the horn button. The crossover wire gets wire-tied to the plastic radiator grid.
Mounted the units with the stock mounting screw on one side, and a radiator mounting screw on the other side. If you're not banned from the FJRForum, look here.
A three-blade terminal looks like this, but any terminal that allows you to piggyback another wire will work.
Harald and NTXFJR loved this
