Engine grenaded...
- Intech
- x 1470
- x 3573
Engine grenaded...
Well, got a call from my brother David last night. The 07 engine gave up the ghost at 104k. Still very young. It gave no signs of a problem. Just let go. Engine is seized. Metal visible in the oil. Looking for a new engine. Any leads would be appreciated. Other option is an 07 in NC that is available. He hasn't made up his mind yet.
- x 11029
- x 4259
Re: Engine grenaded...
Wow...WTF?
- Intech
- x 1470
- x 3573
- Red
- FJRModel: 2008 FJR1300ABX
- x 225
- x 1218
Intech,
Sorry to hear that, man. 104k is too young to fail like that, I agree.
I could see that happening, if the Cam Chain Tensioner failed and the cam chain lost the valve timing. The engine would be toast in a heartbeat.
Cheapest option would be a good engine from eBay or maybe from one of the other want-ads listings. You may be able to use a newer engine, by a year or two, but the correct year would be easiest.
Good luck with the hunt.
- Intech
- x 1470
- x 3573
We will be tearing it down to find the cause. The tensioner was changed around 76k. Any Gen2 engine will work fine (non ES of course).Red wrote: ↑Thu Jun 14, 2018 8:17 am Intech,
- x 48471
- x 20511
If the cam chain tensioner failed, uh yeah.
But this is Bob's old 07 if I understand correctly...so THAT doesn't compute.
- x 48471
- x 20511
No ES Gen 2 engine...did you mean Gen 2 AND Gen 3???...or did you mean no Gen2 AE and any Gen 2...Intech wrote: ↑Thu Jun 14, 2018 8:25 amWe will be tearing it down to find the cause. The tensioner was changed around 76k. Any Gen2 engine will work fine (non ES of course).Red wrote: ↑Thu Jun 14, 2018 8:17 am Intech,
- FJRModel: 2008
- x 3899
- x 6046
That sucks balls. I say we take a ride down to Wheatie's house and steal the engine out his... You know it's never been revved more the 3500rpm.
Hppants, Intech, and Uncle Hud loved this
- x 48471
- x 20511
You must have gone to an Illinois school and can't read. I've owned a GEN 1 and a GEN 3 FJR. Let's see if you can make the next logical step and see why your felonious plan will not work.
0face loved this
- x 955
- x 2759
Someone did an engine swap using an "AE" motor - on the other forum. (JamesK) Not a big deal, apparently although there was a lot of discussion. Don't rule one out if a good one shows up. Probably can swap a few bits from the dead one to make it work just fine.
http://www.fjrforum.com/forum//index.ph ... ?hl=engine
- jwilly
- Site Admin
- x 2249
- x 2148
I guess he learned his lesson not to put the crush washer on the wrong direction!
This blows man!
- x 6289
- x 10359
Just steal the whole bike, it's easier.wheatonFJR wrote: ↑Thu Jun 14, 2018 9:05 amYou must have gone to an Illinois school and can't read. I've owned a GEN 1 and a GEN 3 FJR. Let's see if you can make the next logical step and see why your felonious plan will not work.![]()
As far as the AE engine, can't see why it wouldn't work. The engine is the same. Converting from scratch is hard and expensive but since you'd have all the parts already it "should" be as simple of a swap as a non-ae engine.
- x 48471
- x 20511
I wouldn't. Those AEs are from left over French detuned engines...gixxerjasen wrote: ↑Thu Jun 14, 2018 9:41 amJust steal the whole bike, it's easier.wheatonFJR wrote: ↑Thu Jun 14, 2018 9:05 amYou must have gone to an Illinois school and can't read. I've owned a GEN 1 and a GEN 3 FJR. Let's see if you can make the next logical step and see why your felonious plan will not work.![]()
bungie4 loved this
Any motorcycle engine which has a shift pattern of: Neutral - 1 - 2 - 3 - 4 - 5 shouldn't be trustedgixxerjasen wrote: ↑Thu Jun 14, 2018 9:41 am ...As far as the AE engine, can't see why it wouldn't work. The engine is the same...
- x 7162
- x 7089
Year smear, let's do it! We sell Wheaties motor and give the proceeds to Bob toward the replacement motor.wheatonFJR wrote: ↑Thu Jun 14, 2018 9:05 amYou must have gone to an Illinois school and can't read. I've owned a GEN 1 and a GEN 3 FJR. Let's see if you can make the next logical step and see why your felonious plan will not work.![]()
- x 6289
- x 10359
That's only the electronic part, right?ionbeam wrote: ↑Thu Jun 14, 2018 10:06 amAny motorcycle engine which has a shift pattern of: Neutral - 1 - 2 - 3 - 4 - 5 shouldn't be trustedgixxerjasen wrote: ↑Thu Jun 14, 2018 9:41 am ...As far as the AE engine, can't see why it wouldn't work. The engine is the same...![]()
- x 955
- x 2759
Only the shift drum dictates the shifting order based on the thread I referenced. Still, a good "A" model engine is the preferred choice.
- Intech
- x 1470
- x 3573
Yes. that's what I meant!wheatonFJR wrote: ↑Thu Jun 14, 2018 8:27 amNo ES Gen 2 engine...did you mean Gen 2 AND Gen 3???...or did you mean no Gen2 AE and any Gen 2...Intech wrote: ↑Thu Jun 14, 2018 8:25 amWe will be tearing it down to find the cause. The tensioner was changed around 76k. Any Gen2 engine will work fine (non ES of course).Red wrote: ↑Thu Jun 14, 2018 8:17 am Intech,
- Intech
- x 1470
- x 3573
I can't stand it! I will be heading up there tomorrow to tear it apart.
- FJRModel: 2015 FJR 1300 A
- x 232
- x 74
Sorry to hear about the bro's misfortune with the grenading.
Cam chain tensioner replaced at 76k? Is that normal? Come to think of it, maybe the 07/08 had a weak cam chain tensioner and lots of people swapped them?
Do the later models need a CCT so soon?
