Missing Downshifts - Common Problem?
Sonreir
FJRModel: 2012 FJR1300A
Post by Sonreir »
Hey all,
About a week ago, I started getting a problem with the shifting and it's getting worse. About half the time (especially when going from 3rd to 2nd), the shift misses. The shifter moved freely but it doesn't grab a gear. Upshifting seems fine and my usual fix has been to shift up a gear and then back down again and this sometimes works.
Ideas on the cause of the problem and is there an easy fix that doesn't involve tearing into the transmission?
Re: Missing Downshifts - Common Problem?
Welcome and howdy Sonreir. Click >>here<< and read the thread this takes you to. Write back and let us know if this helps.
x 3982
x 6902
I bought a new pair of boots. Now I can't upshift worth shit.
