Radiator Coolant - How much does it take?
Steel_Gin
FJRModel: 2012 FJR1300A
x 1425
x 446
Post by Steel_Gin »
Sorry about the rookie question but here it is. :D
I'm going to take a swing at changing the radiator coolant and want to know how much it takes. Been looking for a couple hours and haven't found a number for how much the whole system takes so I know how much to buy. (I'm guessing a gallon would be enough.)
I did find the reservoir takes .25 of a quart and that is it. I'm probably not including a specific word when I'm doing my search to find the answer.
Re: Radiator Coolant - How much does it take?
deang wrote: Thu May 10, 2018 8:37 am ...changing the radiator coolant and want to know how much it takes...I'm probably not including a specific word when I'm doing my search to find the answer.
According to the owners manual: 2.75 US qt (2.60 L).
0face, wheatonFJR, and raYzerman loved this
x 47360
x 20106
:D
Steel_Gin
x 1425
x 446
Post by Steel_Gin »
Aw crap!! That's what happens I don't go through the manual page by page. :lol: Thanks!!
x 47360
x 20106
deang wrote: Thu May 10, 2018 9:54 am Aw crap!! That's what happens I don't go through the manual page by page. :lol: Thanks!!
I wouldn't trust the word of someone you just met on the neenernet...I'd still read the manual...just in case. ;)
The nice thing about downloaded PDF Owners Manuals is that they are searchable. Ctrl + F for find. Type in SPECIFICATION or COOLANT or CAPACITY etc. and you will get there PDQ.
That said... When Yamaha initially puts out owners manuals for new model years the manuals aren't searchable but they do have a spiffy index on the left side of the document. Yamaha only releases an interactive PDF on the 6th year and older models, all newer manuals have diagonal red text and are the equivalent of 'pictures' and not text.
x 3766
x 5927
Well really it depends on if you do the super-duper-War-douche-coolant-blow-out change.
Then it takes 45 gallons of distilled water and another 92 gallons of coolant... just to be sure you know.
Make sure you don't have a ticker... Otherwise you might have to ask for donations for a new bike.
Re: RE: Re: Radiator Coolant - How much does it take?
Sorry. Can't see the red banner in Tapatalk. Feel free to delete this post.
x 2360
x 14520
Thank you for contributing a helpful response to the OP's question.
This subforum is on the way to getting the extra special banner at the top so it can be a helpful place without the extra 6 posts of :threadjack:
ionbeam wrote: Thu May 10, 2018 8:54 am
Steel_Gin and rbentnail loved this
x 916
x 2672
ionbeam wrote: Thu May 10, 2018 10:06 am The nice thing about downloaded PDF Owners Manuals is that they are searchable. Ctrl + F for find. Type in SPECIFICATION or COOLANT or CAPACITY etc. and you will get there PDQ.
Unless, of course, you download the owner's manual from the Yamaha Canada site. The manuals are all available and are all PDF that have hypertext table of contents and fully searchable text. You just have to be able to translate KM, Litres and °C to miles, gallons and °F. And put up with the nonsense associated with the immobilizer!!
Start here:
https://www.yamaha-dealers.ca/ymca/web/ ... cale=en_CA
x 3766
x 5927
The second post gave the EXACT answer that was asked for. Anybody reading farther only has themselves to blame. :nhlfight:
extrememarine wrote: Thu May 10, 2018 10:41 am Thank you for contributing a helpful response to the OP's question.
HotRodZilla, Steel_Gin, El Toro Joe and 1 others loved this
x 3996
x 6905
Which turns out, if you use the factory approved, patented, enhanced and improved Yamaha Brand coolant, costs $40/per gal. YammaJizz Diff lube doesn't even cost this much.
Don't ask how I know :oops: :( :o :shock: :withstupid:
x 3434
x 12707
deang, can you wait until tech day? Also you can check corrosion inhibitor effectiveness with a voltmeter, lots of links on the neenernet.
You'll use a touch less than the spec amount, cuz you can't get it all out, maybe a cupful..
x 916
x 2672
Re: Voltmeter check of antifreeze...
I know that this has been claimed. Scientific principles are not (in my opinion) rigorous enough for me to hang my hat on a voltmeter result. (I am a lab geek and make my living running a laboratory that does chemical analysis.) Antifreeze condition is a function of dilution (percent glycol), anti-corrosion additive concentration and presence of contaminants. Pretty sure my multimeter doesn't know all this stuff! I change coolant every two years or whenever I do a valve check (coolant has to be drained for that anyway) and call it good! Although I could, I would never bother with a chemical analysis unless I suspected on-going corrosion problems or head gasket leak - and that would be to confirm a possible mechanical issue, not to see if the coolant was still OK. Antifreeze is cheap, engines are expensive!
Note: Voltmeter is measuring in-situ REDOX (reduction-oxidation) potential of metals in the system due to electrolytic processes (galvanic corrosion) and may be a function of depleted additives. (Glycol itself doesn't wear out) Test tells you nothing about contaminants built up over time or glycol concentration changes due to water evaporation and is only an indicator of POSSIBLE additive depletion. (I apologize for the minor rant!! Internet wisdom is sometimes worth exactly what you pay for it.)
FJRoss wrote:Re: Voltmeter check of antifreeze...
I agree with that.
When I worked on diesel engines that pumped out several thousand hp, they had cooling systems that held 60+ gallons and radiators the size of a garage door. Because it would be extremely cost prohibitive to flush and fill with antifreeze ( a couple thousand bucks at least) they had just the additives in a quart bottle. Dump that in at maintenance time and all would be well. You're right, the glycol doesn't wear out.
x 3434
x 12707
Cool beans all that info, to me I avoid "2 year" motorcycle coolants and get the high miler/long life stuff, change at a valve check and call it a day. I don't exceed 4 years usually......
x 916
x 2672
raYzerman wrote: Fri May 11, 2018 7:49 am Cool beans all that info, to me I avoid "2 year" motorcycle coolants and get the high miler/long life stuff, change at a valve check and call it a day. I don't exceed 4 years usually......
The two year thing usually coincides with my valve check anyway. I think I have only ever changed AF once other than at a valve check and that was when (last year) I had to repair a leaking radiator and replace a degraded plastic overflow bottle.
The long-life OAT (Organic Acid Technology) antifreeze had a bad reputation from the early days of implementation but it is generally considered as safe and suitable for our application. I think if I decided to make the change from the green or yellow stuff to the (typically) orange OAT, I would do a good distilled water flush first - even though they say the formulations are compatible.
x 3996
x 6905
I had a Blazer that at some point before I bought it had the red Dexron shit mixed with the green/yellow shit, the result was something that looked like Jell-O that never fully set. It too a couple of back flushes to get it right.
x 47360
x 20106
bungie4 wrote: Fri May 11, 2018 5:52 pm I had a Blazer that at some point before I bought it had the red Dexron shit mixed with the green/yellow shit, the result was something that looked like Jell-O that never fully set. It tooK a couple of back flushes to get it right.
But, I like jello.
x 3996
x 6905
wheatonFJR wrote: Fri May 11, 2018 6:03 pm
But, I like jello.
Much better than liking being back flushed
