Reset trip odometer (s)
Ok...so I figured out how to do a master reset which resets both odometers...how do I reset them individually?
Re: Reset trip odometer (s)
Did you try the old RTFM technique?
Since you didn't and I have... On the left side of the instrument panel there are two rubber covered buttons. Assuming you have already toggled through the menu and you see the trip meters displayed, push the button with the big "R". The top trip display will start flashing. Push and hold the same R button until that display resets to zero. Push the button again and the second trip meter will begin flashing. Push and hold the R button until that display resets.
That same R button is also used to reset your average fuel economy readout if you wish to reset it at each fuel stop.
LKLD, wheatonFJR, and CollingsBob loved this
- x 47272
- x 20082
Btw, this is in the little owner's manual, not the big Service Manual...in case you don't like to read.
I looked in the owners manual but got distracted trying to find a non-existent centrefold
NTXFJR and Uncle Hud loved this
- x 482
- x 1317
- mcatrophy
- FJRModel: 2018 FJR1300AS
- x 60
- x 661
Be aware you have to do a very short press to start the display flashing, but there can be a significant delay before it does.
If you have more than one resettable display on one screen, you can cycle through them with short presses, then when you have the one you want to reset flashing, a long press will reset just that one.
My web site
