Does anyone out there have a similar tool that MCL offers as a loaner tool tool to drill out the security screws on ignition switch.
I have MCL risers on my bile and want to take them off and move over my other bike. I cannot seem to get in contact with MCL anymore even though web site is up and running. I tried to call and also sent email that got got bounced back.
This is tool I am talking about: http://www.motorcyclelarry.com/index.ph ... cts_id=236
Ignition security screw removal tool
- x 10
- x 2630
- x 2121
Re: Ignition security screw removal tool
No jig, but are you sure there are security screws [bolts] securing the ignition switch? Many installed normal socket-head hex when swapping the clamp. Drilling off the bolt head isn't that big a deal. Carefully center-punch the head, a couple sharp bits and you're done.
Good luck!
--G
Good luck!
--G
Bust, raYzerman, and wheatonFJR loved this
- x 10
Dealer did swap for me and other bike is still factory so I'm sure both have security screws installed.
- x 12962
I'm with G, fixture not required, center punch them, drill carefully and replace with socket head hex screws.
- x 2386
- x 14700
When I installed my Heli-Bar riser, this is what I did. With the top clamp off, I drilled or ground out the fastener head, removed the ignition, then removed the remain portion of the fastener with a set of vise grips. Reinstalled with standard fastener hardware.
Bust loved this
- wetwolf
- FJRModel: 2005 FJR (Tire eater)
1999 Bandit 1200 (The hooligan bike!) - Location: Spokane, WA
- x 26
- x 383
I used a reverse twist bit in the drill, they came right out.
- sacramentomike
- FJRModel: 2023 AE
- x 175
- x 722
It would be tough to do with the riser attached in any way to the bike, at least for me. If you have (access to) a drill press, drilling the bolts out would go a LOT smoother.
- Brodie
- FJRModel: 2008 Advanced Edition
- x 165
- x 170
When I changed out my ignition switch I just used a center punch, cordless drill, and easy out. Did all the work in my lap sitting on a low brick wall. No drill press needed, lap work guarantees careful work.
Brodie
Brodie
