ABS test coupler 90890-03149
The ABS test coupler 90890-03149 is no longer available in North America...however it is still available in the U.K.. I have contacted a Yamaha dealer in Edinburgh who will bring some in for me. The cost is about $15.00CDN each.
I can bring some to Nakusp..pm me if you are interested.
- x 47280
- x 20085
Re: ABS test coupler 90890-03149
I'd be interested...but griff would have to bring it back to me...as he's going and I'm not.CollingsBob wrote: ↑Tue Apr 10, 2018 8:52 am The ABS test coupler 90890-03149 is no longer available in North America...however it is still available in the U.K.. I have contacted a Yamaha dealer in Glasgow who will bring some in for me. The cost is about $15.00CDN each.
Failing that, all you need is a jumper wire to short two pins together, that is all the ABS test coupler is. I've got a procedure written over in the 'Evil Empire Forum'. I'll fetch a link for it shortly.
Link.
Link.
- FJRModel: 2008
- x 3766
- x 5927
You might want to bring the post over here rather than just the link for posterity sake. JSNS.
^^^^^^ Ya, Tech section stuffer for the new On Topic Only repository of Good Stuff. Mebby this weekend.
- x 3432
- x 12689
I ordered a few connectors from Eastern Beaver, comes with terminals, and made mine so it has spade terminals to connect a switch. I mounted it under the battery cover, so all I have to do is reach in and flip the switch if I'm in there. Gen3 has room to put stuff under there.
I made another to take to tech days..... I can make a batch if I get some more connectors, have not dug into costs.....
But those on a budget, jumpering the terminals in the original connector is pretty easy like Allan says. Sky blue to black.
- x 47280
- x 20085
I would definitely check these to make sure the wires aren't upside down.raYzerman wrote: ↑Tue Apr 10, 2018 11:29 am I ordered a few connectors from Eastern Beaver, comes with terminals, and made mine so it has spade terminals to connect a switch. I mounted it under the battery cover, so all I have to do is reach in and flip the switch if I'm in there. Gen3 has room to put stuff under there.
griff and 0face loved this
- x 3432
- x 12689
Then it would be black to sky blue.......wheatonFJR wrote: ↑Tue Apr 10, 2018 12:10 pmI would definitely check these to make sure the wires aren't upside down.raYzerman wrote: ↑Tue Apr 10, 2018 11:29 am I ordered a few connectors from Eastern Beaver, comes with terminals, and made mine so it has spade terminals to connect a switch. I mounted it under the battery cover, so all I have to do is reach in and flip the switch if I'm in there. Gen3 has room to put stuff under there.
With that, each coupler will have the ABS test pins jumped together to enable the ABS tests. It also will have two wires onto which you clip a multi-meter and read pulses to count out error codes. This is one time where an old school multi-meter is superior to a digital multi-meter.
- x 11643
- x 10852
Ray, if you have an extra please bring to Black Hills Roundup II. I'll be glad to purchase from you.
- x 47280
- x 20085
Thanks! I will need to find a Yank going to CFR to mail it to me. I think Cav47 is headed up that way. I'll have him pick it up and mail it.
Time to pm cowface.
- x 3432
- x 12689
I have a spare..... meanwhile, on Gen3, the two wires to jump are the black and Sky Blue with silver/gray tracer.
- silverback
- x 1250
Re: RE: Re: ABS test coupler 90890-03149
So...just a thought...ionbeam wrote:With that, each coupler will have the ABS test pins jumped together to enable the ABS tests. It also will have two wires onto which you clip a multi-meter and read pulses to count out error codes. This is one time where an old school multi-meter is superior to a digital multi-meter.
Most Japanese made automotive products use the same types of connectors. I contend that a trip to the local pick-a-part with a picture of the dummy plug on your cell phone could net you a fairly inexpensive and fully compatible pigtail.
With said pigtail, one could wire in a momentary on push button switch and an LED with appropriate resistor in the correct circuits. Then, one could mount them in an inconspicuous location amd perform ABS diag with the push of a button and read the blinks for codes.
Worth a try?
From another dimension in space & time this has been detailed here. A standard LED with wire legs and a 100Ω resistor in series for the code pins is a real good idea.silverback wrote: ↑Fri May 18, 2018 9:22 am ...could net you a fairly inexpensive and fully compatible pigtail.
With said pigtail, one could wire in a momentary on push button switch ...one could mount them in an inconspicuous location amd perform ABS diag with the push of a button and read the blinks for codes...
- x 47280
- x 20085
...and that is why Sir Alan of Ionbeam is the smartest man on FJRiders. JSNS!ionbeam wrote: ↑Fri May 18, 2018 9:29 amFrom another dimension in space & time this has been detailed here. A standard LED with wire legs and a 100Ω resistor in series for the code pins is a real good idea.silverback wrote: ↑Fri May 18, 2018 9:22 am ...could net you a fairly inexpensive and fully compatible pigtail.
- FJRModel: 2008
- x 3766
- x 5927
Any chance you can/will cut and paste that info here for those of us who are not allowed into Mordor?
I'll get to it, I need to do some updates. Spring is busy with home construction, winter recovery and...... it's racing season! Busy burning all the rubber off this car at the track right now. (The hood is open to help cool the engine for the next round, in theory a cooler intake will make more power.)
- x 47280
- x 20085
^^^^^^^^^^^^^^^^^^ionbeam wrote: ↑Fri May 18, 2018 10:37 amI'll get to it, I need to do some updates. Spring is busy with home construction, winter recovery and...... it's racing season! Busy burning all the rubber off this car at the track right now. (The hood is open to help cool the engine for the next round, in theory a cooler intake will make more power.)
Stock photo...we need video proof with Alan taking off his helmet after the 155mph 1/2 mile run.
