Interesting little trick to remove rusted bolts...
- Gramps
- FJRModel: '13 Tiger Explorer
- x 361
- x 317
CraigRegs, kieefjr, CollingsBob and 2 others loved this
"You know, the very powerful and the very stupid have one thing in common. They don't alter their views to fit the facts. They alter the facts to fit their views." Doctor Who 1/22/1977
Marc
Marc
- x 47330
- x 20098
- blind squirrel
- FJRModel: 2014
- x 1539
- x 2582
Re: Interesting little trick to remove rusted bolts...
What have you got for a broken easy out in a broken bolt on a vertical surface?
- x 47330
- x 20098
Sounds like you need to do a search...like we asked you to do when you signed up. What are you, blind?blind squirrel wrote: ↑Thu Apr 05, 2018 11:19 am What have you got for a broken easy out in a broken bolt on a vertical surface?
EDM. Assuming that the item is valuable to you.
- x 3995
- x 6905
Having had to attempt to drill out a broken easy out, I can say, without equivocation, a nuclear warhead.blind squirrel wrote: ↑Thu Apr 05, 2018 11:19 am What have you got for a broken easy out in a broken bolt on a vertical surface?
Let me expand on my previous post.bungie4 wrote: ↑Thu Apr 05, 2018 11:30 amHaving had to attempt to drill out a broken easy out, I can say, without equivocation, a nuclear warhead.blind squirrel wrote: ↑Thu Apr 05, 2018 11:19 am What have you got for a broken easy out in a broken bolt on a vertical surface?
EDM --or-- MDM.
Either way you would be looking for a machine shop to do the deed. I believe that bungie's suggestion of a nuclear warhead is actually a bit... conservative
wheatonFJR and bungie4 loved this
- silverback
- x 1250
Six $350 carbide endmills to remove a $3 easy out. That's how it works.
- x 482
- x 1319
X-Tractalloy electrodes. Used them many times, they really work!blind squirrel wrote: ↑Thu Apr 05, 2018 11:19 am What have you got for a broken easy out in a broken bolt on a vertical surface?
- blind squirrel
- FJRModel: 2014
- x 1539
- x 2582
After doing some research, I think I will end up going with a Dremel carbide endmill, time, and patience.
- silverback
- x 1250
Re: RE: Re: Interesting little trick to remove rusted bolts...
AND SAFETY GLASSES.blind squirrel wrote:After doing some research, I think I will end up going with a Dremel carbide endmill, time, and patience.
I'm not normally a safety nazi, but carbide is very brittle. Using it in a non-rigid tool (dremel as opposed to a bridegport) it will break. Probably several of them will.
Carbide has an unnatural link to the unholy which guarantees a microfragment will take up residence in your cornea. As much fun as that sounds like, it really isn't. Medical bills are expensive. Pain is undesirable. Safety glasses are as inexpensive as they are dorky looking. Use them.
- x 47330
- x 20098
- x 6112
- x 10062
And you'd be required to add that into your final tally of what it cost to remove the bolt.
- silverback
- x 1250
Looks aren't everything you know!wheatonFJR wrote:NAZI!
