FJR spent winter outside, ride prep?
- wpbfjr
- FJRModel: 2006 manual shift
- x 12
- x 100
my fjr spent the richmond, va winter outside, covered. in addition to battery charge, air check, leak checks, what should i look for/check/change before spring riding.
tia, dana
Sent from my TRS-80
tia, dana
Sent from my TRS-80
signature lost in the mail...
- x 482
- x 1318
Re: FJR spent winter outside, ride prep?
I wouldn't worry about it too much. As the weather warms just ride some and do the "normal stuff": fluid changes, clean-n-lubes, etc. Don't forget to lube the throttle cables. And take a look under the seats and up under side covers and find the wasp nest. Please DAMHIK.
- Uncle Hud
- x 7246
Well, I was hoping others would suggest items to check. Since my FJR has never been "hibernated", I can't really add anything of value. (So I just added a comment that's not valuable .... like I do all the time.)
Bust loved this
- Harald
- FJRModel: 2020 FJR1300ES
- x 268
- x 145
Mice like to take up residence in the air filter, so better pull it and check. Good time to replace it or at least blow it out.
I have a picture of my air filter filled with mouse poison pellets that Mickey stashed there for later consumption. I'm guessing he sampled the wares I left out for him and never made it back to collect his stash.
Steel_Gin, Bust, CollingsBob and 1 others loved this
- x 3432
- x 12690
along with looking under the tank (and elsewhere) for chewed wires..... clean 'er up, fresh fuel, battery charged, go for a shakedown ride, flush and bleed clutch and brakes (activate ABS via a jumper), check tar pressures.
- x 47288
- x 20085
- x 6214
- x 3968
Let's just hope that's not an issue.
- John d
- FJRModel: 2008A
- x 926
- x 647
Looks like everything is covered here. Might check helmet for dust mites.
- wpbfjr
- x 12
- x 100
thanks all!
between weather, late night work, and life events, i feel like a noob to my fjr...
happy trails!
Sent from my TRS-80
those are in the riders head...lol.John d wrote:Might check helmet for dust mites.
happy trails!
Sent from my TRS-80
- x 11643
- x 10853
The bike spent the winter outside, was the fuel tank completely full? Condensation is exacerbated when the fuel tank is only partly full. Moist air is sucked into the tank each time the temperature cycles, the moisture condenses in the tank and eventually settles to the bottom. At a minimum you need to run a bottle of HEAT through the tank, and, if it were mine I would drain the tank and refill before starting the bike.
- x 3043
- x 3382
Next winter just ship it to me and I 'll ride it.....
- x 3986
- x 6902
This.
I have to rewire the accessories on the ass end of my bike (Givi lights, Whelan brake strobe) because some of those little fuckTards decided to make a meal out of mine over the period of one week last year. I was lucky, I remember going down the highway and thinking the truck in front of me had something on fire.. turns out it was under MY ASS!
Went to wash the bike, took the seat off, and then I saw the nest with 3 of those little pink bastards. I turned them into crow sushi.
wheatonFJR, Bust, and bigjohnsd loved this
- Uncle Hud
- x 7246
