voltage readout
palerider
FJRModel: 2006AE
x 26
voltage readout
Post by palerider »
Hi,
If you're in the LA area and are looking for a shop, consider Ryan Reza's AdvMotoTech (https://www.advmototech.com/).
He's got everything sorted on my bike (2006AE)--found/fixed the short and replaced the clutch actuator. Running well, but I've got two questions:
1) What have people done about mounting a voltmeter? I'd like to be able to monitor the voltage lever, but the voltmeters I've found either want to be on all the time (a steady drain) or want to stay on just a few seconds. I can put in an inline switch, but I'd for sure forget to turn it off; or I could put in a relay. Any other ideas I'm not thinking of?
2) There's a noticeable clunk off idle. I'm assuming it's drive-line lash. I can't remember it being there, but that doesn't mean it wasn't. I might just be noticing it now. Regardless, is anyone aware of anything that can be done about that?
GaryK
Palerider
x 15882
x 15017
Re: voltage readout
I use an escort radar detector and it has a setting to display voltage. The circuit for my radar detector is run though my accessory fuse block, and it is set to ignition hot (through the relay). I realize that what it is displaying is slightly lower than battery voltage (across the voltage drop for the r/d circuit), but it gives me a good conservative number.
I wouldn’t worry about the drive line slack. There is a thread on it in the other sandbox, but this seems like overkill to me.
palerider
FJRModel: 2006AE
x 26
Re: voltage readout
Post by palerider »
Thanks, HPPants. I've recently retired, and I think I'm looking for projects. Idle hands....
Palerider
x 13186
x 6371
Re: voltage readout
palerider wrote: Sat Feb 03, 2018 10:49 pm Thanks, HPPants. I've recently retired, and I think I'm looking for projects. Idle hands....
You need some shit to do?? I've got a back yard and some stucco that needs attention. I have a heated garage, and I'll let you watch my T.V.
Cav47 and Hppants loved this
Re: voltage readout
I put this one on mine and have been happy with it. I hooked it up to a fuse block that is switched with a master relay tied to the key switch. This unit draws so little current that I personally wouldn't hesitate to wire it directly to the oem switch circuit if I didn't already have a fuse block.
https://www.amazon.com/gp/product/B00S5 ... UTF8&psc=1
x 3527
x 12967
Re: voltage readout
Search on ebay for several cheap ones, the trick is getting LED's that can be seen in the sun.
Handy thing, Battery Tender makes a plug-in version as well.
https://www.ebay.com/itm/SAE-to-USB-Cab ... 5u&vxp=mtr
I use this one, bright LED's, I mounted it under the 'hood' of my instrument panel on the Gen3. It has a switch on the back to shut it off.
https://www.ebay.com/itm/Waterproof-12V ... _FLkmc34hA
x 15882
x 15017
Re: voltage readout
Incidentally, the stock stator on the Gen III bike is really good. The other day, I'm chugging at 45 mph in high gear (maybe less than 3K rpm), with high beams, aux. LED lights, grip heaters on WFO, and my heated jacket liner on medium. Original battery in the bike. Radar Detector is showing 14.4 and steady (THUMBS UP!!)
palerider
FJRModel: 2006AE
x 26
Re: voltage readout
Post by palerider »
HotRodZilla wrote: Sun Feb 04, 2018 1:13 am
Forgive me for gushing, but it is the selflessness and thoughtfulness of the members of the FJR community that makes it stand out among its peers. :manlove: Thank you, HRZ, for your generosity and willingness to help in what you perceive as my time of need. I assure you that there is no shortage of things to do around here should I proclaim I am at loose(ish) ends, and it is primarily to avoid honey-dos that I seek alternative projects that often involve fixing things on the FJR that aren't broken.
Palerider
palerider
FJRModel: 2006AE
x 26
Re: voltage readout
Post by palerider »
NTXFJR wrote: Sun Feb 04, 2018 2:25 am I put this one on mine and have been happy with it. I hooked it up to a fuse block that is switched with a master relay tied to the key switch. This unit draws so little current that I personally wouldn't hesitate to wire it directly to the oem switch circuit if I didn't already have a fuse block.
Thank you. That's actually the same unit I already bought. Where did you mount it?
Palerider
Re: voltage readout
palerider wrote: Sun Feb 04, 2018 1:20 pm
I put mine here:
palerider
FJRModel: 2006AE
x 26
Re: voltage readout
Post by palerider »
Works for me.
Palerider
x 15882
x 15017
Re: voltage readout
Looks like you get a little sun shading from the bike’s dash. Nice lookkng install
x 3527
x 12967
Re: voltage readout
This is mine... palerider has a Gen2 so will likely need to mount somewhere else.
Re: voltage readout
Ray, I'm liking that accessory bar you have there, what is it?
x 3527
x 12967
Re: voltage readout
:lol: It'll cost you..... made it myself from 2 pieces of 2" Aluminum angle. I'll make you one for like $500. :lol:
Back (front side) view. The engineering that went into that isn't cheap.
NTXFJR loved this
