Dead from the waist down
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Hi,
A follow-up observation on my nearly dead 2006AE, which, thanks to AAA, is at Advanced Moto Tech, an independent shop in Glendale (CA): There's no power going anywhere but the gauges. Turn the ignition key to on, and the gauge lights go on, the tachometer and speedometer needles swing over and back, and the yellow warning light comes on solid, and the warning flashers work. Other than that there's no power to any systems: no starting, no brake lights, and no head lights. I can't find anything in the manual that touches on this. It's wishful thinking, but I can't help hoping I'm overlooking something really simple, obvious, and stupid, like the kill switch, which I've tried.
Without my FJR I feel like I've lost a limb.
Palerider
SLK50
FJRModel: 2006
x 211
Re: Dead from the waist down
Post by SLK50 »
Have you had the ignition switch replaced under recall?
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Yes, the ignition switch has been replaced, but that doesn't mean it hasn't gone bad.
Palerider
x 47298
x 20086
Harness? Spiders?
x 3432
x 12695
Go to FJR Forum and do a search for ground spider. Here is Brodie's harness thread which thankfully still has photos you can view..
http://www.fjrforum.com/forum//index.ph ... g-harness/
There is a diagram showing the wiring for the spiders on FJR Owners , found it!
Note prevalent problems were on '06-'07, but could affect all Gen2's
x 6098
x 10051
Fuse perhaps?
You did ask for simple, obvious, and stupid. :D
palerider
FJRModel: 2006AE
x 26
Post by palerider »
gixxerjasen wrote: Thu Nov 16, 2017 10:52 am Fuse perhaps?
I've yet to find the bottom of my stupid (and that's after 70 years!), so yes, stupid's fine. In fact it's perversely reassuring. But I did check the fuses, and they seem OK.
Palerider
palerider
FJRModel: 2006AE
x 26
Post by palerider »
raYzerman wrote: Thu Nov 16, 2017 10:23 am Go to FJR Forum and do a search for ground spider. Here is Brodie's harness thread which thankfully still has photos you can view..
I've been banned from FJR Forum (felony joking), but I had the harness replaced under recall. That doesn't mean that isn't the problem.
Palerider
x 6098
x 10051
palerider wrote: Thu Nov 16, 2017 11:02 am
Yea, well, I'm happy you brought up the kill switch. I won't mention the number of times I've torn down a bike due to that stupid thing. :roll:
palerider
FJRModel: 2006AE
x 26
Post by palerider »
gixxerjasen wrote: Thu Nov 16, 2017 11:19 am
Thanks. One time I tore the blocked drain in a bath tub apart before I realized that the drain latch was closed. Stupidity loves company.
Palerider
x 13145
x 6352
A couple people have had further "spider" issues with the S6 connector. That one was not affected by the repair harness. May need to lift the tank and check all those ground harnesses. My bet is one is bad.
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Thx!
Palerider
Powerman
FJRModel: 06fjr
x 326
x 1744
Post by Powerman »
Check S-4, the factory recall still has too much current through it.
The drawing shows you the systems it feeds. Ground jumper each pin
and check a device it feeds. Divide and conquer.
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Thx!
Palerider
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Powerman wrote: Thu Nov 16, 2017 7:16 pm Check S-4, the factory recall still has too much current through it.
Blown 15amp fuse. I missed it. Ryan Reza found it. Seems to be a short in the directional-signal circuit.
Palerider
x 6098
x 10051
palerider wrote: Sun Nov 19, 2017 2:28 pm Blown 15amp fuse. I missed it.
*CoughCough*
:mrgreen:
Glad it was something simple...and relatively inexpensive.
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Yes. Phew! Now I have to find the short.
Palerider
x 13145
x 6352
palerider wrote: Mon Nov 20, 2017 1:10 am Yes. Phew! Now I have to find the short.
That's the part that's gonna suck!!
x 3432
x 12695
First place I'd look is up at the turn signals themselves..... those connectors are not waterproof and betcha ya got some green stuff growing up there, maybe shorting across...... dunno why they didn't make these waterproof.
Powerman
FJRModel: 06fjr
x 326
x 1744
Post by Powerman »
You been looking down my pants ?
