Grips...
- silverback
- x 1250
Grips...
What are the preferred aftermarket grips for the FJR? The stock ones are OK, but I think I would like something a bit nicer.
Is the Gen3 heated grip part of the grip its self or can a new grip be installed over whatever heating element there is?
- Auburn
- FJRModel: other ride
- x 2398
- x 1468
Re: Grips...
I believe the heated grips have the elements molded into them
get out and ride!
IBA #708
2024 Goldwing
IBA #708
2024 Goldwing
- x 6276
- x 10350
Re: Grips...
DO NOT CUT THE HEATED GRIPS!!!!
If you have not priced them, you should look at that before you think about tearing them off.
Just throwing this out there to save some heartache.
- silverback
- x 1250
Re: Grips...
I haven't done anything as of yet.
- NTXFJR
- FJRModel: 2016 FJR1300A
- x 2900
- x 1527
Re: Grips...
I put foam Grip Puppies over mine and have been happy so far
Sent from my SAMSUNG-SM-G930A using Tapatalk
Twigg loved this
- x 6276
- x 10350
Re: Grips...
Good, because...rockymountainmc.comsilverback wrote: ↑Thu Jul 27, 2017 12:09 pm I haven't done anything as of yet.
2D2-82963-10-00 (replaces part #2D2-82963-00-00) GRIP, WARMER (LEFT) $277.73 $222.18
- silverback
- x 1250
Re: Grips...
Hmmm. Well that sucks.
Probably difficult to find a replacement grip with the heating element and 125mm length that has some more cushion to it, I'd guess.
- x 6276
- x 10350
Re: Grips...
And finding one that'll work with the computer controlled grips. IIRC it can be done but it's a pain.silverback wrote: ↑Thu Jul 27, 2017 2:38 pm Probably difficult to find a replacement grip with the heating element and 125mm length that has some more cushion to it, I'd guess.
- HotRodZilla
- FJRModel: 07 FJR-A
- x 13186
- x 6371
- FJRModel: 2005 FJR1300A
- x 43
- x 31
Re: Grips...
I love my Lee Parks Outseam gloves ... I am with you on the grip covers, and the cheap ones are excellentHotRodZilla wrote: ↑Fri Jul 28, 2017 12:20 am Get better gloves. Or try the Grip Puppies, Grip Buddies.
https://www.amazon.com/Grab-Motorcycle- ... ip+buddies
Re: Grips...
I'm not a Grip Buddy/Puppy type o' guy. The larger diameter makes my arms ache terribly. I think I've found the best smaller diameter non-heated grips around, Pro Grip 714. I've tried others but keep coming back to these.
https://www.revzilla.com/motorcycle/pro ... port-grips
- silverback
- x 1250
Re: Grips...
I had the ProGrips on my 07. Loved them. But, the 14 is heated grips...
Oh well. I will figure something out.
