Zumo 590 Wiring
JustinNck1
FJRModel: 2006
x 26
x 99
Zumo 590 Wiring
Post by JustinNck1 »
So I am in the process of mounting a Garmin Zumo 590 to my bike. The provided harness had leads to wire directly to the battery. My question is, with the GPS OUT of the cradle, will it drain my battery as it sits overnight? I'd prefer to have it on a switch or ideally on the ignition feed, but I don't have a Fuzeblock yet and I am leaving Saturday. Has anyone else tested this?
x 1425
x 3465
Re: Zumo 590 Wiring
If the GPS is not in the cradle it should not have any load. Get you a fuzeblock, though. It really tidies things up at the battery, as well as, providing switched or un-switched power.
JustinNck1
FJRModel: 2006
x 26
x 99
Re: Zumo 590 Wiring
Well I got the mount wired up tonight. I decided to go ahead and run the wires for a Fuzeblock and when I get back from my trip, install should be a breeze. The GPS is currently wired under the seat and mounted on steering stem nut with ram mount, since I didn't want to stash all the extra wire in the fairings. Gonna test to see if it drains the battery any overnight.
thompsonian
FJRModel: 2015
x 95
x 76
Re: Zumo 590 Wiring
Post by thompsonian »
I still think that as long as the circuit isn't completed that it shouldn't draw any power. Do I need to be sure and pack some jumper cables?
x 47338
x 20103
Re: Zumo 590 Wiring
thompsonian wrote: Thu May 11, 2017 7:19 am I still think that as long as the circuit isn't completed that it shouldn't draw any power. Do I need to be sure and pack some jumper cables?
My gps power is not switched. Unless the unit is on, it shouldn't be drawing power, right?
Of course electricity is magic dust, so I have no idea.
JustinNck1
FJRModel: 2006
x 26
x 99
Re: Zumo 590 Wiring
[/quote]
[/quote]
This is my assumption as well. Just want to double check. I'll check the bike this evening and see if there is any drain on the battery. That would be a full 24 hours, so it should be a good test.
x 3433
x 12704
Re: Zumo 590 Wiring
I have mine unswitched, 'cuz I hate it rebooting after every key cycle. There will be no draw if the GPS is not in the cradle. There are 2 ways to shut down a 590, I'll let you read the manual. One is 'standby' the other is off (but battery will charge).
tominca
FJRModel: 2005 ABS
x 121
x 480
Re: Zumo 590 Wiring
Post by tominca »
The 590 has both an off and standby mode. To turn the unit OFF you must hold the power button down and select off in the screen display. This mode does not consume power. When the GPS is switched, and loses power, it will warn that power is lost and it will go into standby, which is a low power mode that allows faster startup. This drains the GPS internal battery if you leave it in standby for long periods of time. Standby can also happen if you remove the unit from the mount, and don't use the OFF function.
When directly wiring the GPS, the risk is that your simply forget to manually turn it off and leave it in the mount. The GPS draws enough power to potentially affect starting the bike after 24 hours or so, and it can completely drain a battery, which can damage the battery. If it is not switched, be aware, and be sure to shut down the GPS whenever you will be away for more than a few hours. Removing the unit from the mount invokes the standby mode.
Many complaints about the GPS battery not lasting long is caused by not shutting the unit off by holding down the power button.
It's a good day to ride
JustinNck1
FJRModel: 2006
x 26
x 99
Re: Zumo 590 Wiring
Checked the bike after 24 hours of having the mount wired directly, and it didn't drain at all. Looks like I am all set for my trip this weekend.
x 47338
x 20103
Re: Zumo 590 Wiring
JustinNck1 wrote: Thu May 11, 2017 11:14 pm Checked the bike after 24 hours of having the mount wired directly, and it didn't drain at all. Looks like I am all set for my trip this weekend.
This weekend? I thought you were headed down a week from Saturday?
thompsonian
FJRModel: 2015
x 95
x 76
Re: Zumo 590 Wiring
wheatonFJR wrote: Fri May 12, 2017 6:57 am
We're leaving tomorrow morning.
x 47338
x 20103
Re: Zumo 590 Wiring
thompsonian wrote: Fri May 12, 2017 7:25 am
hmmm, if Sunday wasn't Mother's Day I would have met you Saturday night and ridden with you Sunday. Have a great trip!
JustinNck1
FJRModel: 2006
x 26
x 99
Re: Zumo 590 Wiring
wheatonFJR wrote: Fri May 12, 2017 7:46 am
Yeah somehow I got my dates mixed up, this time of the year is chalked full for me. I'll be back down June 7-11 at Fontana Village. Leaving for it June 2 and hitting Ozarks and Natchez Trace on the way there from Ohio.
