Helibars vs Genmar riser
Bigfoot
FJRModel: 2008 AE
x 22
Post by Bigfoot »
Pros and cons of each type, other than the Genmar being less than half the price?
1982 XJ1100
1984 FJ1100
2008 FJR1300AE
The voices in my head are giving me the silent treatment.
Bigfoot
FJRModel: 2008 AE
x 22
Re: Helibars vs Genmar riser
Post by Bigfoot »
Well, now that I have started looking, I see there are more options, Helibar have a two piece setup like the Genmar. Looking for opinions as to whats the best.
1982 XJ1100
1984 FJ1100
2008 FJR1300AE
Best? You cannot be serious!
What HeliBar offers now (as far as I know) is only the Bridge. It offers a LOT of setback and rise plus allows you to open or close the angle of the bars as you adjust the fore and aft setting.
GenMar offers a 7/8 inch rise and the setback is mostly due to the rearward angle of the forks.
Motorcycle Larry (if they are still in business) offers blocks similar to the GenMar but are a full inch high.
The MV Motoradd is similar to the HeliBar Bridge.
GenMar riser blocks on my '15 ES:
HeliBar Bridge on the '07
x 481
x 1312
If you keep an eye on ebay you can pick up an olde style Helibar bridge instead of the bolt on Heli risers. I got one over the winter, brand new, for less than original average retail.
MV Motorrad works mighty fine on my bike. Easy install, too.
x 10726
x 4129
Uncle Hud wrote: Wed Mar 29, 2017 10:25 am MV Motorrad works mighty fine on my bike. Easy install, too.
does it require brake line extension, like the helibar bridge?
El Toro Joe wrote: Wed Mar 29, 2017 11:13 am
No. Which tells me that it does not have as much setback as the HeliBar.
NTXFJR loved this
El Toro Joe wrote: Wed Mar 29, 2017 11:13 amdoes it require brake line extension, like the helibar bridge?
No, no extensions. It's been a while, but I remember THAT'S the reason I purchased the MV version: no extensions to anything. During assembly, you wrestled the brake line through a special adapter, and there's just enough slack to get things adjusted and bolted together.
The handlebars aren't "set back" from the factory position -- or if they are, it isn't much. The MV allows them to pivot a lot, though. Mine are adjusted them such that my elbows are almost at my ribs as I go smiling down the highway.
x 47234
x 20066
Uncle Hud wrote: Wed Mar 29, 2017 1:00 pm
...so you like the "driving the wheelbarrow" stance, ala the 1940s Harleys?
wheatonFJR wrote: Wed Mar 29, 2017 1:05 pm ...so you like the "driving the wheelbarrow" stance, ala the 1940s Harleys?
You say tomato, I say tomatoe .... but yes, it's very comfortable.
x 6194
x 3956
Uncle Hud wrote: Thu Mar 30, 2017 8:27 am
Says Uncle Quayle. :lol:
BruinFJRguy
FJRModel: 2015 FJR 1300 A
x 232
x 74
Post by BruinFJRguy »
Can someone give me advice?
I'm thinking about the Helibar bridge. I DO NOT like too much "pull-back," though. In fact, the angle of the stock setup is irritating. I wouldn't mind the bars being just a little higher and slightly more perpendicular to the bike; in the stock position I feel like I'm twisting my wrists cockeyed in an uncomfortable way.
For perspective, I find the stock bar position on an FJ-09 or Super Tenere much more comfortable. I'd like something closer to that on my FJR, without sacrificing handling in spirited twisty rides.
Anyone have any advice?
