I know this thread's been done elsewhere, but I enjoy reading about how folks customize their bikes, and I occasionally get inspired by some farkles. So I'm starting the same thread here.
Tell us, what have you done to your FJR today?
About a month ago, I mounted an iPad mini on the shelf. I'm trying to develop a tablet-based cockpit.
Turns out not to work very well. Tablet obscures my view of the dashboard -- fuel gauge and turn signals -- when mounted to allow full windscreen travel. Don't want to compromise that. Handlebars turned lock-to-lock without issues.
Was able to easily check route and weather radar on the tablet, but unable to display iPhone controls. (iPhone sits protected in the glovebox, plugged into power and acting as the personal hotspot, but out of sight and out of reach.)
Going back to the drawing board.
x 48438
x 20503
Walked past it on the way to work, but I will get out and ride on some fun roads Saturday!
"Getting inspired by the farkle ideas" huh? I guess that's one way of putting it, I'd call it the keeping the danged checkbook empty syndrome
x 15873
x 15006
Curious Hud - did the I-pad work with your gloves on?
Abercrombie FJR
x 521
x 1827
Post by Abercrombie FJR »
I stopped by the motorcycle school after work this morning to visit the neglected FJR, Tenere, 999, Hypermotard, XR650 and all 17 training bikes. They are quietly waiting for some TLC and warmer weather. Saddest shit I ever seen.
FJRPittsburgh, Niehart, and philharmonic loved this
John d
FJRModel: 2008A
x 929
x 647
Post by John d »
Well not today, but over the last two weeks;
Oil change
Coolant change
Valve check and adjust
Fork oil change
Shock relay arm change-out for one with zerks.
Shimmed Penske shock lower mount
Lubed rear brake pedal pivot
Still coming are;
Throttle body sync.
Shifter linkage lube if I can ever loosen that dam T50 screw without breaking shit with a manual impact tool.
Hppants wrote:Curious Hud - did the I-pad work with your gloves on?
Got some summertime techno-gloves, so yeah, it worked. The iPad was also in an Otterbox waterproof case, and the touch screen gloves worked well through all of it.
Google Maps, however, worked differently on the tablet than on the phone. Couldn't figure out why.
x 2630
x 2121
Last weekend finished annual maintenance on the FJR & Tenere including fresh coolant and clutch and brake fluid change. Now that the snow is gone, I feel a mighty fine ride coming up this weekend! :twisted:
--G
Niehart loved this
x 12530
x 9433
Just some simple fluid changes today. Oil and final drive. There are some slight differences in the body work and procedures that I was used to in the Gen 1.
The drain bolt seemed more accessible on the 04. The body work was more flexible on the "tail" near the oil filter.
Once the garage got heated up with the propane heater, it was very enjoyable
x 15873
x 15006
Josh - did you torque the pumpkin drain bolt?
(dumb ass Pants.....)
x 3894
x 6046
Hppants wrote:Josh - did you torque the pumpkin drain bolt?
He does that several times a day...
Madmudder loved this
x 4057
x 6948
I eyeballed my tires and decided I'm gonna have to change them before SEO. Shit, they still have a couple of K left on them.
Rode her to Braselton to pick up a water meter. It fit easily in the port-side hardcase. Weather was a few degrees above freezing -- literally.
Washed it.
x 12530
x 9433
I did not torque it once
Nor did I do it several times
Prob should read what that torque spec is in the FSM.
With that approach, you might just be able to save some of your eyesight.
x 13186
x 6371
Dude, it's an oil drain bolt, so the torque spec will be FUBAR. If you use the crush washer, go until the washer crushes. If not, goodntite should do it. Don't lose your mind either way, and you should be fine.
Uh 'Zilla? This is Cav47 we are talking to remember? Any instructions to Cav should begin with, "First find a grown up..." :D
Back On Topic: I have not done anything to either of the FJRs today. But I will.
x 11012
x 4249
Rode it to work...YESSS!!!
Rode it to work today in the HOV lane at 65-70 mph while the other four lanes were stopped cold. Yipppeee!
At my HOV-only exit ramp? Two Georgia State Patrolmen and one City of Atlanta motor officer writing tickets to five single-occupant cars. Raised the visor and shouted "Thank, you!'' several times.
