remove left side fairing gen ii
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Hi,
Does anyone know: Is it possible to remove just the left side of the gen2 fairing?
Palerider
SLK50
FJRModel: 2006
x 212
Re: remove left side fairing gen ii
Post by SLK50 »
I'm sure I've done it a few times.
Don't forget the two screws in the "chin" below the radiator.
x 3894
x 6046
Yes. Put a towel or something on the floor as while you undue the turn signal the bottom can rub on the floor. Whoops.
palerider
FJRModel: 2006AE
x 26
Post by palerider »
Thanks!
Palerider
x 6284
x 10353
0face wrote:Yes. Put a towel or something on the floor as while you undue the turn signal the bottom can rub on the floor. Whoops.
Rub the bottom on the floor? This is a problem? Mine has a solid layer of road grime for protection of the valuable plastic under it. :D
FYI, pulling this panel is easier than cleaning it. I pull it when changing the oil because I've yet to get a foolproof method to keep the oil from the filter from not going everywhere. Trust me, this fool has tried everything. :D
Jasen, when changing the oil, remove the lower screw, pull fairing out and put your oil filter box there to hold it away from the engine. Pretty foolproof.....
x 6284
x 10353
That's probably smarter. I've never been accused of that though.
x 3894
x 6046
raYzerman wrote:Jasen, when changing the oil, remove the lower screw, pull fairing out and put your oil filter box there to hold it away from the engine. Pretty foolproof.....
I also wrap that piece with a little tinfoil.
x 11014
x 4249
