Front Fender / Caliper Light Brackets
BikerGeek
x 5421
x 4737
Post by BikerGeek »
I recently purchased a pair of cheap-ass LED lights on Amazon (https://www.amazon.com/gp/product/B00G6 ... UTF8&psc=1) and am toying with the possibility of mounting them either off the front fender mounts or off the brake calipers.
I took a look but didn't come across anything - for those of you who have done this, which option (fender / caliper) did you choose, and what type of bracket did you use (purchased or home-made)?
For a pair of cheap-ass lights, the ones I bought are heavier than I was anticipating so I am thinking that the caliper mount may be a bit more robust and will better handle the weight.
Thanks!
x 6387
Re: Front Fender / Caliper Light Brackets
Andy, I would think either would work, as far as location. I would think that the mount would matter more, to avoid vibration.
But what do I know, I haven't stayed in a Holiday Inn Express in years. :roll:
Geezer
x 76
x 622
Post by Geezer »
I have found that the less you pay for LEDs the heavier they are. I believe it is more expensive to manufacture a heat sink that is lighter.
I would look into mounting the lights where they are unsprung weight. they will get less bouncing that way and unsprung weight is less likely to affect handling.
x 3113
x 3419
I have a pair of Denali D2D's mounted from my fender bolts. I was able to use the supplied Denali mounting brackets with some slight modification to allow the use of the stock bolts. They've been on for almost 4 years with no issues at all. I even did the same with Mona's BMW F800ST.
x 3889
x 6046
Clearwater Lights might sell just the brackets.
Allen_C
x 3
x 283
Post by Allen_C »
A rectangular housing with 6 LEDs might be heavier than you want down there. I have had my lights mounted on the lower fender bolt for three years without issue, but the ES fender is different. If it helps, I replaced the mounting screw provided with the lights with a longer screw that replaces the fender bolt. To keep the U-bracket off the fender, I used a hard rubber spacer between the bracket and the hole in the fender.
x 3519
x 12944
When you showed me those at your house, I gave you the best advice I could........ send them home with me. But did you listen? No, I left empty handed. I coulda solved all your problems.....
BikerGeek
x 5421
x 4737
Post by BikerGeek »
raYzerman wrote:When you showed me those at your house, I gave you the best advice I could........ send them home with me. But did you listen? No, I left empty handed. I coulda solved all your problems.....
I do have another pair on the way...
JSNS
Geek, I don't know if this will help but I have a couple pics. My setup is a kit from MondoMoto but I probably have an extra set of their mounts here somewhere.
I know you have a Gen but the basic idea is the same.
Yeah, I know this on my old ST1300 but you can at least see the "U" bracket.
