Garage door opener hard wired
Madmudder
FJRModel: 2014 FJR1300es Metallic Black
2023 FJR1300es Cobalt Blue
2022 Honda Goldwing tour DCT Blue
x 1853
x 381
Post by Madmudder »
Has anyone wired a Garage door opener to the high beam flash switch on a Gen 3? I seem to recall this was done in the past with an additional switch located where the Menu button is located on a gen 3 and was wondering if someone was able to determine how to make use of the current factory flash button and just hard wire a remote in the fairing somehow using that switch. :?:
2014 FJR1300es
Geezer
x 76
x 617
Re: Garage door opener hard wired
Post by Geezer »
I have not done it, but I seem to remember someone posting up that he had done that on a Gen 1 back in 2005 or 2006 on another forum. The posts was probably lost from one of the hacks at that site years back, but it can be done. It required a switch that fit in the flash-to-pass spot and a couple of wires run to the opener in a remote location. It's a simple design but I don't know how difficult it might be to fit the switch and hide the wires.
x 47258
x 20079
Yeah, that would be nice!
x 6202
x 3958
I thought of doing it, but went with the remote in the tankbag map holder instead. The only issue is at night, where it's difficult to see the button.
x 3431
x 12686
When we were talking, the concept of eliminating the 3V battery in the remote and using the 12V feed from the Flash to Pass switch..... (On Gen2 you can use a left handlebar switch from a '08-'09 C14 which has the FTP switch and is otherwise identical to the FJR switch).
There are a couple of aftermarket options out there, but they run ~$100 or so.
This one requires a remote that has a 12V battery.........
http://www.adrielhenderson.com/blog/201 ... oor-remote
Geezer
x 76
x 617
Post by Geezer »
One of my garage door openers, an older one, takes a tiny 12V battery. It is a Sears opener that is about 30 years old. I don't know what battery the newer one takes.
x 242
x 1888
I went with a keychain version, which works well enough for me.
Not a garage door opener, but we did something similar on my buddy's Sprint ST. He wanted a J&M CB on there, but when mounted on the handlebar, it hit the windscreen when turned. We mounted above his instrument cluster, then I wired the PTT to the FTP switch. The original PTT still works as well.
If you don't want the actual FTP to actually flash your brights anymore, it should be easy. If you want it to still work, it could be done but with some more effort.
Madmudder
x 1853
x 381
Post by Madmudder »
I have the remote that works with a 12v source I just need to figure out where the FTP factory connection is so I can make use of the switch. I don't want to cut into factory wiring so I plan to find the connectors and just tie in to the harness. I will use the switch for both FTP as well as the trigger for the garage door opener. When I get the information I am looking for I'll post back the way I make it work & photos for those interested.
It was easy to do on the gen 1 & 2 but the 3rd gen makes use of the previous area with the menu selection button.
2014 FJR1300es
x 3764
x 5927
I bought on of those mini openers that are meant for a keychain. Programmed it to my door and Velcroed it under the glove box lid.
x 10729
x 4133
0face wrote:I bought on of those mini openers that are meant for a keychain. Programmed it to my door and Velcroed it under the glove box lid.
I also have a small remote, velcroed inside the glove box...works for me.
Madmudder
x 1853
x 381
Post by Madmudder »
I also have been using this method over the yrs. I just want to make it more simplistic and integrated. It is easy enough to do in warm riding conditions but when heavy gloves are being utilized i find it difficult to do. Once I accomplish my goal it will not be an issue, no more changing batteries and the range is much further that the keychain is. Not to mention the ease and simplicity of using the switch already available. I believe the connection i'm looking for is above the headlight from what I can gather in the service manual. I'll make it my winter project that will likely be completed before Christmas :D
2014 FJR1300es
x 3764
x 5927
Do the gen 3's have the actual ftp switch? I got one off eBay and tied it to key my mic for the 2-way radio.
Sent from my porn viewer.
gixxerjasen loved this
x 47258
x 20079
0face wrote:Do the gen 3's have the actual ftp switch? I got one off eBay and tied it to key my mic for the 2-way radio.
Yes they do Marty.
Those bright lights meant move the f@$k over, I'm passing on a curve! :stickpoke:
x 3764
x 5927
Ahhhh... That's what you've been doing... I guess the middle finger wave you get in return means "thanks for letting me know!"
Harald
FJRModel: 2020 FJR1300ES
x 268
x 145
Post by Harald »
Same here. This has worked great for years now, although I just recently glued a very small nut onto the outside of the opener where you push so that it's easier to actuate with heavy gloves on. Still running the same mini 12 volt battery too.
x 3764
x 5927
Didn't Wheaton get mad you took one of his?
x 47258
x 20079
Oh, I get it. Small nut.
Ha ha.
Weak. :stickpoke:
BTW, I got nuttin on this garage door thread.
kieefjr
x 154
x 150
Post by kieefjr »
Posted this elsewhere but that little red button is wired to a remote battery operated GD opener, velcroed under the fairing.
Imagephoto hosting sites
x 3764
x 5927
wheatonFJR wrote:
0face wrote:
Harald wrote: Same here. This has worked great for years now, although I just recently glued a very small nut onto the outside of the opener where you push so that it's easier to actuate with heavy gloves on. Still running the same mini 12 volt battery too.
Ha ha.
Weak. :stickpoke:
I just can't pass up an opportunity... It's kinda like ice cream without getting fat.
its just rain
Post by its just rain »
On my '14 I installed a dash to mount my GPS, turns out it's the perfect place to Velcro a garage door opener. I siliconed the heck (no water gets in) out of it then stuck it to the underside of the shelf. You really don't even see it.
